[FAQ] DIY 94-01 Integra Maplight in 92-95 Civic
Old Aug 14, 2006 | 12:16 PM
BlueIntegraBoy's Avatar
Default [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic
This is a followup to Airbag Club's DIY EK Maplight thread. The following can be done in your EK, but the 12v wire color may be different. Also, this will not work with 92-95 Civic EX or Si because of the sunroof motor.
Integra maplights can be found on eBay for about $15-20 shipped.
Items needed
- Maplight assembly, Part #34256-ST7-003ZD (Beige) or 34256-ST7-003ZA (Grey)
- 18-20 gauge wire
- Soldering iron and solder
- Wire stripper (I prefer to use a razor blade)
- 1 female space connector
- 1 ring terminal
- Cardboard
- Box cutter, razor blade, or EXACT-O knife
- Black, blue, red, pink, purple, or whatever color pen
- Flathead screwdriver
1. Take your maplight and on the back, you will see flat metal pieces on the left and right side. Use a small flathead and pry those out slightly. Cut about a ~7-8" strip of wire and another ~4" strip. Strip about 1.5" at one end of the 7-8" strip and same with the 4" strip. Wrap the stripped end around the flat metal plates and twist them together. Take the other end of the 4" strip and strip off about .5" and bridge the other flat metal plate by wrapping the 4" strip with the 7-8" strip. Solder your wires. These are your grounds.
2. Cut a ~2-3' piece of wire and crimp on the female spade connector onto it.
3. Take a piece of cardboard and make a 5" x 1 1/16" retangular template. Cut it out.
<FONT COLOR="red">No picture, self explanatory</FONT>
4. Take that template and trace it onto the headliner, wherever you please (centered or off-centered, up to you).
5. Take your box cutter, razor blade, or EXACT-O knife and cut along the inside of your outline.
6. Pull your interior fuse or negative side of your battery.
7. Remove your a-pillar by prying to the left side first.
8. Remove your driverside sunvisor and sunvisor bracket.
9. Splice and solder the ~2-3' wire to the white/blue wire running alongside your a-pillar and run it inside your headliner to the hole you just cut out.
10. Connect the female spade connector to the maplight.
11. Crimp a ring terminal onto the ground wire coming from the maplight and use the bolt for the sunvisor bracket for the ground.
12. Install the maplight. If you cut the headlight correctly, the maplight will fit snuggly.
13. Reinstall all interior pieces removed and the interior fuse (or battery terminal).
Modified by BlueIntegraBoy at 12:19 PM 8/18/2006
Old Aug 14, 2006 | 12:33 PM
Harryflores's Avatar
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (BlueIntegraBoy)
Nice write up and DIY
Old Aug 14, 2006 | 12:54 PM
shyboi4u's Avatar
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (Harryflores)
nice write-up. i was thinking about doing that. i know it japan they have the maplight on some models. i thought it would bolt up? it's held by prongs right?
Old Aug 14, 2006 | 06:10 PM
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (shyboi4u)
Unlike the Integra, the Civics don't have screw holes. It's held up by prongs on the side.
Old Aug 25, 2006 | 02:54 PM
lcjarrett's Avatar
Good write up HiloBoi...
I got that installed in my ek 4DR.
Old Sep 26, 2006 | 10:31 PM
A.E Motoring's Avatar
damn that ***** pimp, i likes is it pretty bright?
Modified by SPNFEDEH at 11:49 PM 9/26/2006
Old Sep 26, 2006 | 11:10 PM
civicEXtreme's Avatar
Looks sweet, Maybe I'll attempt it some day.
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (SPNFEDEH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH &raquo;</TD></TR><TR><TD CLASS="quote">damn that ***** pimp, i likes is it pretty bright?
Yes, it is. Way brighter than the dome light. It's very convenient.
Old Sep 26, 2006 | 11:14 PM
good ****, i wanna try it
Old Sep 26, 2006 | 11:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH &raquo;</TD></TR><TR><TD CLASS="quote">good ****, i wanna try it</TD></TR></TABLE>
I have an extra maplight for sale with all the wiring.
https://honda-tech.com/zerothread?id=1722279
Old Sep 26, 2006 | 11:33 PM
FalkenSiR's Avatar
******* sweet man
Old Sep 26, 2006 | 11:44 PM
eg6sir-s's Avatar
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (fast95eg8)
nice job
Old Sep 27, 2006 | 12:48 AM
.MilanoRex's Avatar
very cool, I might try this
Old Sep 27, 2006 | 05:28 AM
instrument's Avatar
this is like so cool...sursly
Old Sep 27, 2006 | 10:44 AM
CO_CReX's Avatar
Great DIY writeup! Im going to have to try this out.
Old Oct 19, 2006 | 07:58 AM
sohcvtec1995's Avatar
Default Re: (CO_CReX)
anyway to do it witha si hatch?
Old Oct 19, 2006 | 08:38 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: (sohcvtec1995)
sweet!...nice write-up
Old Oct 19, 2006 | 09:02 AM
cxSHOE's Avatar
nice write up. also on 92-95 si will have the brackets under the headliner so instead of soldering wires to the negative side as you screw it on those hole have a metal lining and that is your negative ground and all you do is connect a positive wire to the other tab.
i use this personally. i can get another one if anyone is interested $85 shipped and fits 92-95 civic's that have a sun roof (double check to make sure you have the brackets under the headliner)
Old Oct 19, 2006 | 09:57 AM
Kruzen510's Avatar
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">
What does this one come off of?
Old Oct 19, 2006 | 10:57 AM
cxSHOE's Avatar
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (Kruzen510)
the one im getting from japan is coming of a 95 civic sir II hatch. used, working with bulbs. this was an optional item did not come standard. will only work with sunroof cars due to the larger indentation/swoop in the headliner.
Old Nov 14, 2006 | 06:46 PM
wlee112's Avatar
what is this i hear about the EG ex coupe not fitting a maplight? what is it about the sunroof motor blocking it or something?
Old Nov 14, 2006 | 07:15 PM
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (wlee112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wlee112 &raquo;</TD></TR><TR><TD CLASS="quote">what is this i hear about the EG ex coupe not fitting a maplight? what is it about the sunroof motor blocking it or something?</TD></TR></TABLE>
Bingo
Old Nov 15, 2006 | 08:57 PM
wlee112's Avatar
can you explain it a little betteR? there is absoluetly NO room?
Old Nov 15, 2006 | 10:09 PM
Default Re: (wlee112)
I haven't tried in an EX or Si. But there's a mounting plate behind the ceiling on the EX/Si. The mounting plate interferes with the mounting of the light.
Old Feb 25, 2007 | 12:49 AM
wlee112's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">This is a followup to Airbag Club's DIY EK Maplight thread. The following can be done in your EK, but the 12v wire color may be different. Also, this will not work with 92-95 Civic EX or Si because of the sunroof motor.
Modified by BlueIntegraBoy at 12:19 PM 8/18/2006</TD></TR></TABLE>
look at the motor.. its located to the rear of the sunroof.. are you sure the motor would be in the way?
