funny noise before vtec
Old Aug 14, 2006 | 11:17 AM
hialeahzbg's Avatar
Default funny noise before vtec
my friends motor makes like a bogging noise before vtec... still pulls but makes that funny noise... this once happens to one of my boys that had a built head and he just tuned it and it fixed the problem but this is a itr block with a stock gsr head so why would tuning be an issue? reason y im curious is because i will be buying this motor in about 5 days and i want to know whats wrong with it....only happens like 1st and 2nd gear that you actually hear it...rolling 3rd,4th and 5th u hear the crossover perfect...please help me fellow HT guru's....
Old Aug 14, 2006 | 11:36 AM
THC07's Avatar
Default Re: funny noise before vtec (hialeahzbg)
timing????
mine buzzzezzz before the crosswover??? go figure
Old Aug 14, 2006 | 11:41 AM
hialeahzbg's Avatar
does it only do it like 1 and 2nd gear? i might do it 3rd but not noticable...is it the dizzy or actual timing belt...what should i look for?
Old Aug 14, 2006 | 11:42 AM
THC07's Avatar
Default Re: (hialeahzbg)
ive had similar issues when i installed stage 2 cams on a SOHC. id play with timing, advance it a little bit.
Old Aug 14, 2006 | 11:51 AM
hialeahzbg's Avatar
yea that happen to my friend when he had his head built and put s2s2 cams but my motor is stock....itr block and gsr head...so turning the dizzy will make it better?it idles fine...how do i know when its right? turning it and driving it?
Old Aug 14, 2006 | 12:13 PM
qfast817's Avatar
http://www.team-integra.net/se...D=235
shows how to and more info
Old Aug 14, 2006 | 12:20 PM
hialeahzbg's Avatar
lol looks like its a very good thread but i dont know much about motors....i just drive them...
Old Aug 14, 2006 | 01:14 PM
hialeahzbg's Avatar
so its timing and not tuning?
Old Aug 15, 2006 | 07:35 AM
hialeahzbg's Avatar
which way do i turn the dizzy to advance it?
Old Aug 15, 2006 | 11:47 AM
THC07's Avatar
frontwards. lol
Old Aug 15, 2006 | 12:23 PM
hialeahzbg's Avatar
ok if im standing infront of the dizzy by the passanger fender i turn it to my right correct? and very little or alot? car idles fine so how do i know its been fixed? tighten it and drive it?
Old Aug 15, 2006 | 07:45 PM
THC07's Avatar
jump the service connector first. then you can adjust timing. use a light. 16 is stock, turn it to the left from passenger fender. you can turn car off and just turn it a little if you want, but then you will have to reset the ecu by upluging it. I have my sohc all the way and then back just a tad, not recomended but i could care less its a sohc and it runs best there.
Old Aug 17, 2006 | 11:13 AM
hialeahzbg's Avatar
oh
superhatchbackbros
Oct 6, 2010 03:49 PM
joshblaze101
Aug 26, 2009 09:02 PM
walsh22
Jun 3, 2007 10:59 AM
B204door
Dec 8, 2006 10:34 AM
Peasonrice
Nov 3, 2005 11:13 AM
