Prelude SH Radius Rods
Old Aug 14, 2006 | 09:15 AM
integra15's Avatar
Default Prelude SH Radius Rods
So their are 3 different radius rods available for the SH
The service manual says nothing about which one does what. It just says that they are different in length by 2.5mm and that it can correct for caster being slightly off.
So if you wanted to increase caster which one would you buy? The " + " radius rod, believing that the + stands for increasing caster?
Or do you buy the " - " believing that since the arm is shorter by 2.5mm that would make the caster larger than what it was (the shorter arm would force the wheel further forward)?
Old Aug 14, 2006 | 09:25 AM
vinuneuro's Avatar
Default Re: Prelude SH Radius Rods (integra15)
I believe the 2.5mm diff between each of the colored radius rods is .5 degree change in caster. -2.5mm would decrease the caster by .5* and vice versa. btw, which side radius rod do you need and does it need to increase or decrease caster for your situation?
Old Aug 14, 2006 | 09:34 AM
integra15's Avatar
Default Re: Prelude SH Radius Rods (vinuneuro)
I need to increase the caster on the right. At first I had the same thought as you. Then I realized if you decrease the rod length (-2.5mm) it would move the LCA more forward, thus increaseing the caster?
I could be wroung though.
Old Aug 14, 2006 | 09:37 AM
ninja 6's Avatar
you can always add more washers where the radius rods meet the crossmember (i think) to add/reduce caster. Tire shops do it often, i'm told.
Old Aug 14, 2006 | 09:40 AM
integra15's Avatar
Default Re: Prelude SH Radius Rods (fish stick)
I wish it were that easy. On an SH you can't do that. It's times like these I wish I had bought a base prelude. Stupid car keeps throwing codes and disabling the ATTS anyway.
Old Aug 14, 2006 | 09:52 AM
ninja 6's Avatar
just be glad your car isn't a dime a dozen
Old Aug 14, 2006 | 09:56 AM
vinuneuro's Avatar
The SH radius rod is actually a better design, since it only allows vertical movement of the arm. If you need to increase caster, you do need -2.5mm to pull the lca forward, thus increasing the angle between it and the uca. You want the radius rod with white color coded dot. Straight from helms.
Old Aug 14, 2006 | 05:58 PM
RaceCity_USA's Avatar
Banned
Be aware that increasing the caster beyond the stock spec will adversly affect bump steer. The outer tie rod end will be too low causing the wheel to toe in in bump.
Old Aug 15, 2006 | 09:24 AM
integra15's Avatar
Default Re: Prelude SH Radius Rods (RaceCity_USA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceCity_USA &raquo;</TD></TR><TR><TD CLASS="quote">Be aware that increasing the caster beyond the stock spec will adversly affect bump steer. The outer tie rod end will be too low causing the wheel to toe in in bump.</TD></TR></TABLE>
Thanks for the info. Right now I am just trying to get it back to "normal" I'll post the results if I get it fixed later.
Old Aug 25, 2006 | 12:28 PM
integra15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">The SH radius rod is actually a better design, since it only allows vertical movement of the arm. If you need to increase caster, you do need -2.5mm to pull the lca forward, thus increasing the angle between it and the uca. You want the radius rod with white color coded dot. Straight from helms.</TD></TR></TABLE>
I just verified this, you need the - rod to increase the caster. Thanks
DeleriouS25
Aug 15, 2007 08:15 PM
K2e2vin
Jun 12, 2006 01:10 PM
kornerk12
Mar 23, 2006 12:00 PM
mntdewred
Jul 11, 2002 02:06 PM
