d16y8 head and intake mani will if fit on d16y7?
Old Aug 14, 2006 | 08:53 AM
s2k3_oc08's Avatar
Default d16y8 head and intake mani will if fit on d16y7?
d16y8 head and intake mani will if fit on d16y7? do i need to replace(ecu) somthing or just straight swap? help pls thanks!!!!
Old Aug 14, 2006 | 09:01 AM
Syndacate's Avatar
Default Re: d16y8 head and intake mani will if fit on d16y7? (s2k3_oc08)
It's pretty straight forward, if you're doing it to add the VTEC onto your non-VTEC engine it's called a mini-me swap (putting a VTEC head on a non VTEC engine).
There's some good write ups if you look around.
Here's one that's specific for your engine.
https://honda-tech.com/zerothread?id=735196
Also might wanna refer to this one from time to time if you get stuck - I feel it's more thorough. Please note that this one is for a 92-95 though, the principles are the same, I would follow the 96-98 one (the first one) - but if you get stuck, you could always look at that second link and see if you can find an answer b4 creating a topic.
Tazmania_boy
20
Sep 9, 2012 11:22 PM
straightshot08
Oct 29, 2009 06:36 AM
