Ring Gaps On Hasting Rings 81.5mm w/RS Machine Pistons
I just want to double check because I have never assembled anything but stock rings or JE rings in a 81.5. I just want to be sure, I have to log some miles on this on and want to be 100% sure.
the pistons should have come with a spec sheet that should tell you what the ring gaps should be.
im gonna take a guess and say you can use the ring gap specs in the helms manual since the RS Machine pistons are cast alum just like the OEM pistons are so the specs should be similar.
Like I said, I just wanted to be 100%. and the pistons and rings are a second hand sale, they were new and I knew the seller but the spec sheet never made it.
