4 1/2 or 5qts of oil?
Old Aug 14, 2006 | 06:13 AM
motormike40's Avatar
Default 4 1/2 or 5qts of oil?
How much oil goes in a b18b? And what kind are y'all running? Ive been driving an old bug for the past 3 yrs, so please excuse my ingornace.
Old Aug 14, 2006 | 07:13 AM
orangebarius's Avatar
Default Re: 4 1/2 or 5qts of oil? (motormike40)
4 qts
Old Aug 14, 2006 | 07:25 AM
Padawan's Avatar
Darth ModerVader
It's a little over 4 quarts (I'm at work now and don't have the exact capacity, but it can be found in the owner's manual). When doing an oil change, I normally fill it with four, and then add a little at a time while checking the dipstick to ensure the correct amount.
Old Aug 14, 2006 | 07:31 AM
PrinceAli132's Avatar
Default Re: 4 1/2 or 5qts of oil? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">It's a little over 4 quarts (I'm at work now and don't have the exact capacity, but it can be found in the owner's manual). When doing an oil change, I normally fill it with four, and then add a little at a time while checking the dipstick to ensure the correct amount. </TD></TR></TABLE>
x2 and i pour a little into the new filter before putting it on.
Ali
Old Aug 14, 2006 | 07:54 AM
Danziver's Avatar
Default Re: 4 1/2 or 5qts of oil? (orangebarius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangebarius &raquo;</TD></TR><TR><TD CLASS="quote">4 qts</TD></TR></TABLE>
Old Aug 14, 2006 | 08:41 AM
Nors's Avatar
I do 4 qts, let the oil settle, check it, add ussually a quarter to half a quart.
Old Aug 14, 2006 | 09:08 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Nors)
The spec in the manuals is 4.0 quarts for the B18B1 engine (Integra LS, RS, GS) and 4.2 quarts for the B18C1 (GS-R) and B18C5 (Type R).
5W30 is preferred at all temperatures; 10W30 is also acceptable at temperatures over 20 degrees F.
We use synthetic 5W30 (either Mobil 1 or Pennzoil Platinum) in our '94 GS-R and '01 ITR.
Wal-Mart sells oil cheaper than Sam's Club or Costco. At Wal-Mart, Mobil 1 is $5.47 for a quart and $21.97 for a 5-quart jug; Pennzoil Platinum is $3.99 for a quart and $18.97 for a 5-quart jug. You can get a $15 MasterCard gift card on the purchase of six quarts of Pennzoil Platinum.
Old Aug 14, 2006 | 09:11 AM
Cool, thanks alot, I appreciate it
Old Aug 14, 2006 | 10:08 AM
Padawan's Avatar
Darth ModerVader
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">The spec in the manuals is 4.0 quarts for the B18B1 engine (Integra LS, RS, GS)</TD></TR></TABLE>
Oops. I read too quickly and automatically saw "B18C".
Old Aug 14, 2006 | 11:16 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I always put in exactly 4 quarts when I do an oil change, and my oil level is always a little above the upper hole on the dipstick, even after starting it (to get oil into the filter) and waiting awhile, and even after letting it drain for at least 10 minutes (hot engine).
Old Aug 14, 2006 | 12:28 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I always put in exactly 4 quarts when I do an oil change, and my oil level is always a little above the upper hole on the dipstick, even after starting it (to get oil into the filter) and waiting awhile, and even after letting it drain for at least 10 minutes (hot engine).</TD></TR></TABLE>
My experience with the GS-R is similar. I just had the GS-R in for major service. I gave them exactly 4.2 quarts to use for the oil change. Afterwards, the dipstick reading was 1/4 quart high.
Old Aug 14, 2006 | 04:37 PM
skinnyshugg's Avatar
actually , b18b1 holds 4.9 U.S. quarts (4.6 liters) gs-r and type r hold 5.1 U.S. quarts (4.8 liters)
Old Aug 14, 2006 | 05:01 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (skinnyshugg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skinnyshugg &raquo;</TD></TR><TR><TD CLASS="quote">actually , b18b1 holds 4.9 U.S. quarts (4.6 liters) gs-r and type r hold 5.1 U.S. quarts (4.8 liters) </TD></TR></TABLE>
Only for a complete rebuild.
Old Aug 14, 2006 | 05:57 PM
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
Only for a complete rebuild.</TD></TR></TABLE>
nah same for regular oil change my short friend
Old Aug 14, 2006 | 06:05 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skinnyshugg &raquo;</TD></TR><TR><TD CLASS="quote">nah same for regular oil change my short friend</TD></TR></TABLE>
Wrong.
The GS-R and ITR both take 4.0-4.2 quarts for an oil and filter change. Put in 5.1 and it will be overfilled by a quart, and you'll risk foaming.
Dogginator's Avatar
Daisy... Daisy...
nah same for regular oil change my short friend </TD></TR></TABLE>
I think not.
From the Helm:
B18C1/B18C5 oil change + filter: 4.2 US Qt.
B18C1/B18C5 oil change only: 3.9 US Qt.
B18C1/B18C5 engine overhaul: 5.1 US Qt.
B18B1 oil change + filter: 4.0 US Qt.
B18B1 oil change only: 3.7 US Qt.
B18B1 engine overhaul: 4.9 US Qt.
99.5% chance that I am taller than you.
Old Aug 14, 2006 | 06:07 PM
I think not.
From the Helm:
im only 5'9" lol , whats your source for specs?
Old Aug 14, 2006 | 06:20 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skinnyshugg &raquo;</TD></TR><TR><TD CLASS="quote"> whats your source for specs?</TD></TR></TABLE>
He already stated that the information was quoted from the Helm manual, though the same specs can be found in the Integra owner's manual.
Old Aug 14, 2006 | 06:22 PM
Default Re: (Padawan)
He already stated that the information was quoted from the Helm manual, though the same specs can be found in the Integra owner's manual. </TD></TR></TABLE>
didnt see that , im drunk
Old Aug 15, 2006 | 09:31 AM
WalkerGSR1's Avatar
Why is 5.1quart for a rebuilt engine. Don't they use the same size oil pan?
Old Aug 15, 2006 | 09:41 AM
Community Builder
Default Re: (WalkerGSR1)
Probably because you'll never get all the oil out of the engine just draining it through the oil pan drain hole. When you rebuild an engine, most likely all the oil from all the little passageways and everything will be out of there before you put it back together.
Old Aug 15, 2006 | 09:58 AM
DC4KiD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I always put in exactly 4 quarts when I do an oil change, .</TD></TR></TABLE>same here
Old Aug 15, 2006 | 01:40 PM
Exeed's Avatar
Default Re: (DC4KiD)
YOu know guys.. I've been wondering something. When I change my oil, I put in 4 qts. And then add a little bit at a time untill it's at the top hole. And then it's all fine and dandy. But I drove around with it for a few days... and when i checked it this morning it was a ABOVE the top dot. I'm aware of the problems this may cause, but can someone help me out with this? I have a 96 SIR-G JDM. Thanks in advance
Old Aug 15, 2006 | 04:48 PM
mxl36o's Avatar
my GSR... 3.8 and then let it run and check again...if needed put it .2
never needs more than 4
Old Aug 15, 2006 | 04:50 PM
Fat Chick Magnet's Avatar
i use 4.5 quarts
