93 integra LS transmission will a type r Lsd fit???
Old Aug 14, 2006 | 05:18 AM
dash's Avatar
Default 93 integra LS transmission will a type r Lsd fit???
I have a 93 LS transmission, Does anyone know if a OEM Lsd (type-r) will fit? Or is some thing like a quaife the only answer.
thanks dash
Old Aug 14, 2006 | 05:23 AM
JDMorgan's Avatar
it will fit if you grind the case. only takes a few min. you will need either a gsr or itr final gear to match. why are you using an ls tranny?
Old Aug 14, 2006 | 06:19 AM
motormike40's Avatar
Are you going turbo'd? That could be the only reason why id use the ls trans, I plan on doing the same thing :-)
Old Aug 14, 2006 | 07:05 AM
dash's Avatar
Default Re: (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">it will fit if you grind the case. only takes a few min. you will need either a gsr or itr final gear to match. why are you using an ls tranny?</TD></TR></TABLE>
just what i have to work with at the moment, and finding a cable gsr is imposable and expensive.
so i can't use the ring gear from the ls.......
Old Aug 14, 2006 | 12:45 PM
dash's Avatar
Default Re: (dash)
Any one else have any insite into modifying the case or any other problems i may encounter?
Old Aug 14, 2006 | 02:06 PM
JDMorgan's Avatar
Default Re: (dash)
the ls final will only accept lsd's made for an si or ls ring gears. it wouldn't be that much to buy a 99-00 si or 92-01 gsr gearset, and installation would probably be included in whoever does your tranny work. this way you have a complete short geared tranny with lsd. in fact i have a 99 si gear set for sale.
ls trannies are crap for any race car. my turbo car has the equivelent of a type r tranny. i am running an ls tranny on my gsr powered da, just because i don't want to deal with finding one. car is a daily driver and doesn't need to be fast.
HatchSpeeD
Jul 30, 2006 05:03 AM
Slimm-rw-
Apr 5, 2004 12:01 AM
speedy108
Feb 19, 2004 03:56 PM
meanteg
Sep 7, 2003 12:05 PM
ChuTHIS
Jun 25, 2003 04:22 PM
