Front end feels loose
Old Aug 14, 2006 | 04:22 AM
Ed 341's Avatar
Default Front end feels loose
At about 80mph my front tires feel pretty loose with the steering wheel on-center. Its not noticeable below 80. The steering wheel stays straight on straight roads so I don't think it is the alignment. I have Falken Azenis 215s that are worn but still have about 3/16" tread left.
Any ideas where I should start? Tires, Alignment, wheel bearings?
Old Aug 14, 2006 | 04:31 AM
RTW DC2R's Avatar
you sure this isnt just your tires "tracking" in the grooves, dips, inconsistencies of the road? my last set of tires "tracked" all over the place after they were worn.
Old Aug 14, 2006 | 04:34 AM
Ed 341's Avatar
Default Re: (RTW DC2R)
I'm hoping thats what it is...but it happens at 80 consistently. The front end feels disconected...is that likely with these tires?
Old Aug 14, 2006 | 07:53 AM
94rs-turbo's Avatar
sounds like tires not getting very much traction
Old Aug 14, 2006 | 08:12 AM
Edwin's Avatar
Put the car on a hoist or jack.
Check for play on the wheels bearings, check for play on the tie rods, rotate the tires (front to back), rebalance the wheels, check alignment.
Good luck.
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (94rs-turbo)
have you checked your wheel bearings?
Old Aug 14, 2006 | 08:54 AM
Ed 341's Avatar
Default Re: (walker111)
I checked them the other day...maybe im not sure what to be looking for. The wheels didn't seem to move when the car was in the air.
Old Aug 14, 2006 | 04:02 PM
Ed 341's Avatar
Default Re: (Ed 341)
I rotated the tires..I think one was over inflated (even though I check regularly). It was worn to the wear bars in the center. Problem solved temporarily
sd619jef9
Nov 5, 2011 10:14 PM
born2lose
Suspension & Brakes
Jul 11, 2010 06:12 AM
mikeunreal2
Jun 3, 2007 12:12 PM
sikcrx80
Aug 25, 2003 01:52 AM
Jer'rome
Aug 12, 2003 08:24 PM
