HELPPPPPPPPPPPPP!!!!!!!!!!!! WIRE TUCK!!!!!!!!!!!!!!!!!
Old Aug 13, 2006 | 11:12 PM
latinracerct's Avatar
Default HELPPPPPPPPPPPPP!!!!!!!!!!!! WIRE TUCK!!!!!!!!!!!!!!!!!
please help me out with this i need to know how to tuck the big engine plugs on the sides i got the headlights done but damn i want to hide em all injector plugs etc......... please help me out!!!!!!!!!!! thanks
Old Aug 14, 2006 | 06:15 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: HELPPPPPPPPPPPPP!!!!!!!!!!!! WIRE TUCK!!!!!!!!!!!!!!!!! (latinracerct)
There's not a book on how to do a wire tuck, it's all common sense. Find places to hide things, extend/reloom/retape accordingly.
Here are two threads for referrence, maybe you can pic up some ideas...
https://honda-tech.com/zerothread?id=1693934
https://honda-tech.com/zerothread?id=1401203&page=1
Old Aug 14, 2006 | 10:45 AM
Default Re: HELPPPPPPPPPPPPP!!!!!!!!!!!! WIRE TUCK!!!!!!!!!!!!!!!!! (NAallTheWAY)
thanks that helps but just wanted to know exactly where the plugs are if under dash or tucked under the intake mani just a little confused on what to do
Old Aug 14, 2006 | 10:51 PM
bump up
Old Aug 15, 2006 | 12:06 AM
mekanism's Avatar
When I did mine I had to rebuild the entire harness. Its much easier with the engine out of the car. For the injectors you have to unloom it then re-loom so you have #1,2 injectors paired and #3,4 paired so when you shove them up through the manifold they stay together but tucked nicely under the manifold like so-
For the the under dash stuff what I had to do was pull the entire harness through the firewall and into the cabin so that the fuse box could be tucked up behind the air tube that goes between the fan and the heater core. Your A/C must be removed to do this though! Once the wires have been pulled through you can then pull just the engine harness back out just enough to route behind the rear engine mount and tuck behind the IM. Its hard to explain without pics but I dont have any sorry. The reason for pulling the harness through the firewall and then back to the engine side again is becasue the stock harness is very long. You only need about 3 ft of harness coming from the firewall. The rest just tuck away inside the cabin under the dash. There will be a few wires that need to be shortened and lengthened but once you dive into it it will start to make sense.
There will never be written instructions on wire tucks so you just have to go for it and figure things out along the way. Keep in mind to take your time so that you dont make mistakes and have your engine throwing codes and stuff!
Old Aug 15, 2006 | 08:30 AM
CRXBart's Avatar
Default Re: HELPPPPPPPPPPPPP!!!!!!!!!!!! WIRE TUCK!!!!!!!!!!!!!!!!! (mekanism)
Got bling!!!!
Old Aug 15, 2006 | 09:10 AM
BlackLudeSi's Avatar
Default Re: HELPPPPPPPPPPPPP!!!!!!!!!!!! WIRE TUCK!!!!!!!!!!!!!!!!! (CRXBart)
word, polished everywhere
Old Aug 15, 2006 | 09:49 AM
tampabitches's Avatar
well i wanted to do a wire tuck and someone told me that i had to exstend every wire
Old Aug 15, 2006 | 06:50 PM
mekanism's Avatar
Default Re: HELPPPPPPPPPPPPP!!!!!!!!!!!! WIRE TUCK!!!!!!!!!!!!!!!!! (BlackLudeSi)
I fail to see how polished is bling. I think chrome is bling but polished looks clean IMO. However I will be painting the valve cover gold later!
Old Aug 15, 2006 | 07:44 PM
ok so how does this have anything to do with wire tucks anyway bump
Bartman201
Lighting
Jun 2, 2013 05:55 PM
Brian_midwest
Mar 20, 2011 09:11 PM
clemsoncb7
May 11, 2005 04:47 AM
Buck99Si
Feb 6, 2005 07:22 PM
REPSOL
Sep 14, 2001 05:46 PM
