A/C is bowing white smoke sometimes. But, it doesn't smell like burning smoke.
Old Aug 13, 2006 | 10:58 PM
MAX PAYNE's Avatar
Default A/C is bowing white smoke sometimes. But, it doesn't smell like burning smoke.
The strange think about it is on and no smoke. Then I turn it off and on again, then it smokes. But, if I turn it off and on again it goes away. I have a 1995 dohc vtec del sol. It has a crack cam seal. That I'll be fixing soon. But I doubt it's oil burning. Oil burns black. I do smell gas when I start the car and I always have the ac already in on position and never smokes. Should I be worried. I'll check in later. Please help.
Old Aug 14, 2006 | 05:49 PM
MAX PAYNE's Avatar
Default Re: A/C is bowing white smoke sometimes. But, it doesn't smell like burning smoke. (MAX PAYNE)
What is this more of a electrical issue? You telling none has ever experience this kind of a problem.
Old Aug 14, 2006 | 05:56 PM
LSEGHATCH's Avatar
You ever open up a freezer when the blower is on? I'm guessing it's just the initial start up and being so cold.
Old Aug 14, 2006 | 05:59 PM
MAX PAYNE's Avatar
Default Re: A/C is bowing white smoke sometimes. But, it doesn't smell like burning smoke. (LSEGHATCH)
Wow! I never thought of that. I guess, I'll let it run to see if it disappears. I just didn't want to burn my car down. You know what I mean. Thanks.
Old Aug 14, 2006 | 06:04 PM
LSEGHATCH's Avatar
If it's white I highly doubt anything is catching fire.
Old Aug 14, 2006 | 06:52 PM
ITR EG's Avatar
Your AC is probably running too cold. Next time it does it turn the temp **** a little warmer and see if it goes away. If it does make sure to keep an eye on it cause it could cause issues with your AC system if it freezes on you.
v8killaz
Sep 4, 2010 05:29 PM
bosco500
13
Oct 3, 2005 06:12 AM
1990civicsi
Aug 8, 2004 06:33 PM
T_SweepeR_BB6
Dec 6, 2003 08:39 PM
greenhornet
Oct 27, 2002 04:42 PM
