Extended lug nut install help.... PLEASE!!!
Old Aug 13, 2006 | 08:55 PM
harrykong's Avatar
Default Extended lug nut install help.... PLEASE!!!
I was wondering if any one has a how to on installing extended lugs on my dc2....
link would be great the front are cake but would like to know before ripin out the rear
thanks
Old Aug 13, 2006 | 09:07 PM
E46Kid's Avatar
Default Re: Extended lug nut install help.... PLEASE!!! (harrykong)
bump for you its going to be a pain in the ***
Old Aug 13, 2006 | 09:13 PM
RHDintegXsi's Avatar
Default Re: Extended lug nut install help.... PLEASE!!! (Em1Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Em1Kid &raquo;</TD></TR><TR><TD CLASS="quote">bump for you its going to be a pain in the *** </TD></TR></TABLE>
i 2nd the PAIN IN THE *** part
the fronts you will have to pull the hubs..extended studs are too long to manipulate behind the hub while its still pressed in..
the rears you can cheat.. if you cut off the heatsheild theres just enough room to get that stud in
Old Aug 24, 2006 | 06:46 AM
harrykong's Avatar
bump SWeet for another pain in the *** but makes my car even sweeter pain in my pie whole JOB!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 24, 2006 | 09:12 AM
davidluko's Avatar
Do you mean extended lug studs? Also one more question, is there a purpose to it or is it just for the looks or what? Kinda funny cause I was thinking about this a day or two ago, wondering what it's for.
Old Aug 24, 2006 | 09:34 AM
Solscud007's Avatar
get a hub puller. remove your wheels. and rotors. remove the hub nut and pull the hub out. Pound out the stock lugs and then pound in the new ones. reverse everythign i jsut said.
Old Aug 24, 2006 | 12:45 PM
CNSK's Avatar
Default Re: (Solscud007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 &raquo;</TD></TR><TR><TD CLASS="quote">get a hub puller. remove your wheels. and rotors. remove the hub nut and pull the hub out. Pound out the stock lugs and then pound in the new ones. reverse everythign i jsut said. </TD></TR></TABLE>
you dont need a hub puller....just use a big socket....forgot the size...press against the hub and pound it out...and then pound the lugs out as you stated.....
Old Aug 26, 2006 | 07:16 AM
harrykong's Avatar
Default Re: (Hatch_R)
yeah man extended lugs look sexy with some nice gabs "drools"
any stickies on this guys?
RHD DA6
Jul 8, 2008 11:51 PM
jb07_
May 28, 2008 09:34 PM
raresi99
Jan 26, 2008 04:55 PM
JdMeF9SiR2
Jun 28, 2007 11:24 PM
j nepo
Dec 19, 2004 11:44 AM
