Question about the EL gauges?
Old Aug 13, 2006 | 07:36 PM
thomas188's Avatar
Default Question about the EL gauges?
I have the base model prelude, just got the turbo manifold and I have a t3 with a .63 ar .5 trim garrett air research, I have seen the write up for the cluster change but the question that i cant seem to find the answer to is: Since I have a different transmission than the SI's do will I need to have the speedometer calibrated? I know the gears are not much different than in the SI but taller. Any help that is thrown at me is greatly appreciated... Thanks a lot
Old Aug 13, 2006 | 09:35 PM
snowblind7x's Avatar
Default Re: Question about the EL gauges? (thomas188)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thomas188 &raquo;</TD></TR><TR><TD CLASS="quote">I have the base model prelude, just got the turbo manifold and I have a t3 with a .63 ar .5 trim garrett air research, I have seen the write up for the cluster change but the question that i cant seem to find the answer to is: Since I have a different transmission than the SI's do will I need to have the speedometer calibrated? I know the gears are not much different than in the SI but taller. Any help that is thrown at me is greatly appreciated... Thanks a lot</TD></TR></TABLE>
changing the cluster would have absolutely no affect on anything like that. It would work just fine.
Old Aug 14, 2006 | 08:47 AM
dickeytk's Avatar
Default Re: Question about the EL gauges? (snowblind7x)
it's not going to be any different, the speedo measures the wheels spinning, not the transmission, it's next to the differential. The speedo moves with the wheels, what will make a difference though, is tire size.
1cpu
Jul 7, 2007 09:39 AM
EK FLY
Aug 18, 2006 12:31 PM
lv6l
Apr 23, 2006 11:04 AM
0ptimus prime
Jan 17, 2005 02:01 PM
Street_Kings
Sep 23, 2003 11:06 PM
