b16 into 91 crx si
Old Aug 13, 2006 | 07:03 PM
Drew17th's Avatar
Default b16 into 91 crx si
so i have a wierd question...
i am putting a b16a into my crx and besides wiring vtec do i have to do anything else.... i know its plug and play with my SI harness.... but a friend something about crank angle sensor so im just curious....
thx in advance
Old Aug 13, 2006 | 08:17 PM
Drew17th's Avatar
Default Re: b16 into 91 crx si (Drew17th)
bump
Old Aug 13, 2006 | 08:20 PM
crxnj's Avatar
its an obdo b16a swap?
Old Aug 13, 2006 | 08:30 PM
abnaasefmb's Avatar
Default Re: b16 into 91 crx si (Mr.speaker)
not plug and play but still very easy with a little research
Old Aug 13, 2006 | 08:32 PM
abnaasefmb's Avatar
Default Re: b16 into 91 crx si (abnaasefmb)
http://www.norcalcrx.org/droppedcrxsi/
Old Aug 13, 2006 | 09:04 PM
Drew17th's Avatar
yea mine is obd-0...
Old Aug 13, 2006 | 09:08 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th &raquo;</TD></TR><TR><TD CLASS="quote">yea mine is obd-0... </TD></TR></TABLE>
ok then all you gotta do is add the wires for vtec solenoid,vtec pressure/w ground wire,knock sensor,and 2nd o2 sensor,,then pin those wires into the ecu clips and thats about it...also you may have to extend a wire or 2 but thats about it.
Old Aug 13, 2006 | 09:16 PM
Drew17th's Avatar
ok lol... why i need 2nd o2 sensor??? my ls in there now does not have one..... just curious lol... im using a pw0 for my ecu...
Old Aug 13, 2006 | 09:19 PM
SmogKing's Avatar
I have same set up, no need to hook up 2nd 02 sensor.
Old Aug 13, 2006 | 09:50 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th &raquo;</TD></TR><TR><TD CLASS="quote">ok lol... why i need 2nd o2 sensor??? my ls in there now does not have one..... just curious lol... im using a pw0 for my ecu...</TD></TR></TABLE>
because the stock obdo pr3/pw0 ecu looks for 2 o2 sensors...you'll notice the stock b16 header has 2 o2 sensor bungs on it...1 plugs into the stock crx connector but the other will need to be wired in..
You dont have to hook it up,,but the car will not run right,,and it will bog
Old Aug 14, 2006 | 03:49 PM
Drew17th's Avatar
then can i ask where to hook the second one up too??? becuz my header has a spot for one and my high flow cat doesnt have a bung???
Old Aug 14, 2006 | 04:01 PM
doublethink's Avatar
factory location is on runners as shown there.
what mr. speaker is talking about is a factory pr3 ecu will look for that second o2 sensor. its best to use it. or chip the ecu not to look for it.
that is 100% true, so do ir right.
Old Aug 14, 2006 | 06:23 PM
HondaPartsHero's Avatar
Technical Hero
knock, VTEC solenoid, Second O2, VTEC pressure switch
Old Aug 14, 2006 | 07:15 PM
boostedblkef's Avatar
Default Re: b16 into 91 crx si (HondaPartsHero)
absolutly listen to mr speaker he know his ****
Old Aug 17, 2006 | 08:11 PM
QuickRexSi21's Avatar
Default Re: b16 into 91 crx si (pittbullracer)
I would wire the second O2 sensor
Old Aug 17, 2006 | 08:21 PM
crxsteve's Avatar
true mr speaker knows his **** A+++++++
Old Aug 17, 2006 | 08:45 PM
Loserkidwac's Avatar
Default Re: b16 into 91 crx si (crxsteve)
I've head you can just tap the wire for the secondary O2 into the Primary O2 wire, anything wrong with this method? ECU still gets 2 readings just from one sensor...
Old Aug 17, 2006 | 08:51 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">I've head you can just tap the wire for the secondary O2 into the Primary O2 wire, anything wrong with this method? ECU still gets 2 readings just from one sensor...</TD></TR></TABLE>
yeah you can do that but it wont run right...with the ecu it sees the air mixture for each pair of cylinders seperatly,,so if you do it like that it will run either rich or lean,,you'll notice bogging,,etc,etc..
if you dont want to deal with the o2 sensors then just chip the ecu to see 1 or no o2 sensor
Old Aug 17, 2006 | 08:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
if you dont want to deal with the o2 sensors then just chip the ecu to see 1 or no o2 sensor</TD></TR></TABLE>
Cool, thanks for the info
Fairburn
Sep 2, 2009 06:51 PM
alscrx
15
Oct 19, 2007 10:39 AM
Anti-Drama Queens
22
Nov 16, 2005 02:24 PM
barry11j
Nov 9, 2004 05:21 PM
GeeSeeR
Jul 29, 2001 08:23 AM
