93 ls Clutch
its pretty much like this https://honda-tech.com/zerothread/907431.
but except you have to play with the shift linkage, rather than the cable shifter.
that link should give you an idea on how to do it.
unbolt the tranny from motor. take out starter, unplug any lines on the tranny. take off axle nuts, axle plate on driver side and finally pop out the axles. you can undo the bolts at the shifter and drop that instead of taking out the linkage pin. work them mounts out and i think that should be it. replace the spring and cable while ur there too
