what's the problem??! my braking light stays on!!!!!!!!!!!!
my braking light (the light that tell other driver to stop) stay on even when i'm not braking or when the car is turn on.. my point is, it stays on! 24/7.. wat could b the problem?
Modified by sirrvanna at 3:49 PM 8/13/2006
the braking light, not the one on the cluster, u kno when u brake, the light tell the other people that ur braking.. yeaaaaaaaaaaaaaa, that kind of brakin light
Its most likely the small peice of plastic on the brake pedal that is supposed to hold the switch in when the brake pedal is not pressed.
That peice gets old and brittle and eventually falls apart. Take a good look down at your brake pedal and you'll see the little push-button, and an empty hole where something should go to push in on the button. The plastic "button pusher" is probably in little peices on the floor.
You can fix it with a nut and bolt pretty easily. Good luck!
THANKS A MILLION FIREANT!!!! but i didn't use nuts or bolt, coudlnt' find any so i use phloem.. hahaha THANKS AGAIN!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">#13 in the diagram before and after :
Location in the real world:
i wish mine broke like that, but it's in a million pieces. haha literally
</TD></TR></TABLE>i wish mine broke like that, but it's in a million pieces. haha literally
Any dealership should be able to order it in for you if they are still being made (I bet current pedals still use them). A small nut/bolt will work, a "speed nut" from an autoparts place will work. Some tape would work for a little while.
oscarlx
Jul 1, 2012 08:54 PM
AFAccord
Nov 1, 2005 02:25 PM
SuicideSlide
Jan 13, 2005 08:42 AM
94GSRRacer2
Jul 3, 2004 03:22 PM
