Tuning Question about a/f ratios
Old Apr 25, 2002 | 05:47 AM
MPH's Avatar
MPH
New User
Default Tuning Question about a/f ratios
When I tuned my car I shot for 13.0ish a/f from 4000 to 8500 rpm. Now i was thinking that if the car is moving, more air should be getting to the filter therefore maybe leaning it out. Could this be why you here people saying that they tuned the car to perfection on the dyno, but ran slower times at the strip? I have a open loop ecu so I think it runs the same map all the time. What do you guys think?
Old Apr 25, 2002 | 10:23 AM
MPH's Avatar
MPH
New User
Default Re: Tuning Question about a/f ratios (MPH)
Well I just found out that the general rule of thumb on a/f ratios is that you could lean out up to 5 points from the dyno to the street. In case anyone gives a f00k.
Old Apr 25, 2002 | 10:49 AM
Padawan's Avatar
Darth ModerVader
The dyno should have large fans, so I can't see how there would be a great difference in the amount of air getting to the filter.
Old Apr 25, 2002 | 10:56 AM
MPH's Avatar
MPH
New User
Default Re: Tuning Question about a/f ratios (Spec.R 00-0123)
Icebox is basically ram air, so at high speeds (which I don't think a fan can duplicate) would theoretically lean out some.
Old Apr 25, 2002 | 10:59 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
I've read (in the AEM EMS manual) that you should tune on the dyno with race gas and then you'll be safe on the street with pump gas. A dyno puts more load on the engine than the street does. Judging from that statement, I don't see how you could be leaner on the street.
Old Apr 25, 2002 | 01:06 PM
mafay2's Avatar
New User
I think it very depeneded on the intake system and the dyno environment. So I think it is very difficult to estimate the actual difference between the dyno and real time driving condition. I would just tune to its best on the dyno and wouldn't worry about it.
Old Apr 29, 2002 | 10:24 PM
jonnybravo's Avatar
13 sounds kind of lean for that area. You might wanna shoot for 12.9-12.5.
jdmcoop
Jun 19, 2011 08:56 PM
airmaxbri
May 1, 2010 08:34 AM
mrx
Sep 12, 2005 04:50 AM
2point6
Aug 31, 2005 04:22 PM
nightrider
Jan 18, 2004 04:46 PM
