98 GSR wont start
well i was driving along and i noticed the power cutting out.. then the car stalled and wont start. The check engine light did not come on.. So i checked to see if there were any ecu trouble codes. when i did this the engine light didn't flash it sayed on. (what does this mean). So i changed the plugs which looked like hell and it still wont start. The bad plugs could explain the loss of power when i push the throttle. But as for not starting im lost.. My guess is a fuel problem.. Any help
Is it even trying to turn over? Have you checked to make sure you're getting spark? (pull a spark plug wire, put a 1/4" extension in it and hold it next to metal while someone tries to turn your car over)...
1stgenboost
Jan 16, 2013 02:10 PM
EKcpe00
Nov 14, 2010 02:27 PM
steviethekidd
Jun 25, 2005 02:09 PM
