anyone using EXEDY OE replacement clutchs?
Old Aug 13, 2006 | 10:29 AM
Flava's Avatar
Default anyone using EXEDY OE replacement clutchs?
so whose all using one and what are your mods/driving style?
Old Aug 13, 2006 | 10:38 AM
syntax.'s Avatar
Default Re: anyone using EXEDY OE replacement clutchs? (The Source)
Im pretty sure Exedy and Daikin are the same company, so i have one. Its mated with a Fidanza flywheel and i havent had any problems at all. If you are planning on turboing or using spray, it probably wont hold up for long. If you ride on the clutch and let it drag, or do a ton of launches without letting it cool down it will start to slip.
Overall, i like it because its cheap and its still easy to drive in stop and go traffic if you need to, perfect for a daily driver with minimal bolt on mods.
Old Aug 13, 2006 | 10:41 AM
Flava's Avatar
Default Re: anyone using EXEDY OE replacement clutchs? (syntax.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax. &raquo;</TD></TR><TR><TD CLASS="quote">Im pretty sure Exedy and Daikin are the same company, so i have one. Its mated with a Fidanza flywheel and i havent had any problems at all. If you are planning on turboing or using spray, it probably wont hold up for long. If you ride on the clutch and let it drag, or do a ton of launches without letting it cool down it will start to slip.
im thinkin of not using an aftermarket flywheel and just keep the stock one. dont plan on anything more than the regular intake, header , exhaust for a long time.
Old Aug 13, 2006 | 10:46 AM
syntax.'s Avatar
if you reuse the stock flywheel make sure you take it to a machine shope to get it resurfaced. Shouldnt cost more than $40 or so. If you dont, there is a good chance that the new clutch will "chatter" and probably wont last as long.
Good luck
Old Aug 13, 2006 | 10:48 AM
Flava's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax. &raquo;</TD></TR><TR><TD CLASS="quote">if you reuse the stock flywheel make sure you take it to a machine shope to get it resurfaced. Shouldnt cost more than $40 or so. If you dont, there is a good chance that the new clutch will "chatter" and probably wont last as long.
Good luck</TD></TR></TABLE>
what is chatter? but thanks for the heads up.
Old Aug 13, 2006 | 11:21 AM
syntax.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Source &raquo;</TD></TR><TR><TD CLASS="quote">
what is chatter? but thanks for the heads up.</TD></TR></TABLE>
you'll get at vibration and it will be kinda jumpy when you are slowly taking off from a dead stop. It can be kind of annoying. Think of it like the vibration from a warped rotor, except its your flywheel/clutch. Sucks.
Old Aug 13, 2006 | 11:26 AM
Flava's Avatar
you'll get at vibration and it will be kinda jumpy when you are slowly taking off from a dead stop. It can be kind of annoying. Think of it like the vibration from a warped rotor, except its your flywheel/clutch. Sucks.</TD></TR></TABLE>
that does suck. thanks for the help
well anyone else using this clutch?
Old Aug 13, 2006 | 11:32 AM
v4lu3s's Avatar
RTFM
exedy is the sprt division of Daikin clutches
and it is funny that the clutch makers say you must surface, whle honda says not to....
Old Aug 13, 2006 | 12:29 PM
Flava's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">exedy is the sprt division of Daikin clutches
and it is funny that the clutch makers say you must surface, whle honda says not to....</TD></TR></TABLE>
is there anything wrong with getting it resurfaced?
Old Aug 13, 2006 | 03:49 PM
v4lu3s's Avatar
RTFM
i have had an aftermarket one resurfaced. I jstu found it odd that honda flat out says do not resurface the flywheel.
When i had mine done the machine shop pulled the dowel pins, then surfaced teh flywheel, and the surfaced th outside edge to keep proper step height. Cost me $75 which is more than i expected to pay but still cheaper than another flywheel.
Old Aug 13, 2006 | 03:56 PM
jzobie1's Avatar
i got the exedy clutch with the 11lb XTD flywheel (it was cheap) from clutch city or something like that on Ebay and the clutch and flywheel are great so far its just the throw out bearing that was no good from the start.
Old Aug 13, 2006 | 05:16 PM
Flava's Avatar
Default Re: (jzobie1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">i have had an aftermarket one resurfaced. I jstu found it odd that honda flat out says do not resurface the flywheel.
When i had mine done the machine shop pulled the dowel pins, then surfaced teh flywheel, and the surfaced th outside edge to keep proper step height. Cost me $75 which is more than i expected to pay but still cheaper than another flywheel.</TD></TR></TABLE>
werid. is there anything wrong with resurfacing an oem one tho?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jzobie1 &raquo;</TD></TR><TR><TD CLASS="quote">i got the exedy clutch with the 11lb XTD flywheel (it was cheap) from clutch city or something like that on Ebay and the clutch and flywheel are great so far its just the throw out bearing that was no good from the start.</TD></TR></TABLE>
what did you do about the throw out bearing? what was wrong with it?
Old Aug 17, 2006 | 07:48 PM
Flava's Avatar
bump
Old Aug 17, 2006 | 08:42 PM
DJ_SaNdOz's Avatar
The Exedy OEM clutches have served me well in a few different vehicles . I've resurfaced the flywheels in all of my Honda's without issue, I wouldn't do a clucth job w/o resurfacing or getting a new flywheel.
Old Aug 17, 2006 | 08:43 PM
Flava's Avatar
Default Re: anyone using EXEDY OE replacement clutchs? (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">The Exedy OEM clutches have served me well in a few different vehicles . I've resurfaced the flywheels in all of my Honda's without issue, I wouldn't do a clucth job w/o resurfacing or getting a new flywheel.</TD></TR></TABLE>
what motor and mods have you done to the ones you used the exedy oem clutch?
Old Aug 17, 2006 | 08:44 PM
DJ_SaNdOz's Avatar
d and b series, just the normal bolt onstuff.
Old Aug 17, 2006 | 08:47 PM
Flava's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">d and b series, just the normal bolt onstuff.</TD></TR></TABLE>
how long did they lastand what kind of driving did you do?
im going to be doing the usually dd, street racing (i know i know), drag strip every once in awhile...etc.
Old Aug 17, 2006 | 09:16 PM
v4lu3s's Avatar
RTFM
Default Re: (The Source)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Source &raquo;</TD></TR><TR><TD CLASS="quote">werid. is there anything wrong with resurfacing an oem one tho?
its the same process as aftermarket, its jstu that honda has put out several bulletins saying dont bother resurfacing, if it has excessive heat spotting, warpage, or wear they say replace it.
Old Aug 17, 2006 | 09:26 PM
Flava's Avatar
its the same process as aftermarket, its jstu that honda has put out several bulletins saying dont bother resurfacing, if it has excessive heat spotting, warpage, or wear they say replace it.</TD></TR></TABLE>
ohh ok. i guess we'll see when i get the motor what i need to do.
Old Aug 18, 2006 | 08:08 AM
esedulerp5tenin's Avatar
i have the exedy stage 1 (OEM replacement) with fidanza 8lb flywheel.
its absolutely perfect for a daily driven, weekend drag racing and autocrossing, and i am very pleased
altho, i had 0 intentions of boosting when i bought the pair, and now that i do have intentions, i'm expecting it to go not very long after i bOOOstt
but i am very pleased with the setup
Old Aug 18, 2006 | 08:13 AM
darkspector2.0's Avatar
Exedy OE replacement.. stock flywheel
Running for quite a while no probs... well... none that weren't my own fault LoL
Old Aug 18, 2006 | 08:26 AM
Default Re: (darkspector2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkspector2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
Running for quite a while no probs... well... none that weren't my own fault LoL</TD></TR></TABLE>
i hear you on that one man
nice avatar too.... copier
Old Aug 18, 2006 | 09:13 AM
Default Re: (esedulerp5tenin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin &raquo;</TD></TR><TR><TD CLASS="quote">
nice avatar too.... copier </TD></TR></TABLE>
hey hey great minds think alike!
I glazed my clutch something awful trying to go up hill in stop and go traffic in second....
OOPS!
Old Aug 18, 2006 | 11:12 AM
Flava's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkspector2.0 &raquo;</TD></TR><TR><TD CLASS="quote">Exedy OE replacement.. stock flywheel
what do you mean by none that werent your own fault?
Old Aug 18, 2006 | 02:03 PM
OOPS! </TD></TR></TABLE>
RemerLex11
Dec 20, 2010 08:50 PM
G2_Fella
Aug 18, 2008 08:37 AM
DFW
24
Aug 7, 2006 01:15 PM
94whtgsr
Aug 17, 2004 07:04 PM
DeDonDeRosa
Jun 13, 2003 02:05 PM
