My Tranny is binding up.
Old Apr 25, 2002 | 04:35 AM
sackdz's Avatar
Default My Tranny is binding up.
I just installed a JDM FD and 3-4 synchro into my transmission. When I test fit the case, with the circlip in the countershaft groove, everything works perfectly. But when I torque down the case bolts, the thing binds up and I can no longer turn it over, even with 2 hands turning a clutch on the shaft. When I loosen the case bolts, it's fine again.
What could be the problem>?
Old Apr 25, 2002 | 08:34 AM
sackdz's Avatar
Default Re: My Tranny is binding up. (sackdz)
eY!
Old Apr 25, 2002 | 08:58 AM
sackdz's Avatar
Y21 Tranny
Old Apr 25, 2002 | 11:00 AM
earl's Avatar
I'm no tranny expert but it's happened to me before also. Seems like it was not in the area that you worked on. I think it was the ring gear/ spool assembly was not completely in position. As long as the case was not bolted tight, everything was perfect. As soon as I would tighten it down, the final clearance was knocked to zero and would lock up. Look in that area first. Good luck
Old Apr 25, 2002 | 09:21 PM
Rocket's Avatar
Default Re: My Tranny is binding up. (earl)
Try just bolting the tranny together with just the mainshaft and then see if it still binds. This way, you can check if you re-assembled to mainshaft back properly after changing the 3rd and 4th gear synchros.
Hope this helps. Tranny's can be fustrating.
[Modified by Rocket, 6:22 AM 4/26/2002]
Old Apr 25, 2002 | 09:35 PM
b19coupe's Avatar
Default Re: My Tranny is binding up. (Rocket)
If you don't line up the tangs on the friction collars with the holes in the gear sleeves, that will cause binding when you torque the case.
Old Apr 26, 2002 | 08:40 AM
sackdz's Avatar
Default Re: My Tranny is binding up. (b19coupe)
I did install just the mainshaft and try. It still binds when torqued down.
The collars you are referring to are the brass rings with the springs, right? I double checked the mainshaft assembly, everything looks good.
HOWEVER. The top bearing on the mainshaft sits above the end of he shaft a little (5-6mm). Is it supposed to be flush or close to flush? If so, I can't find what's keeping from dropping all the way.
One note, the 3-4 synchro hub doesn't look like it slides completely onto the grooves of the mainshaft (maybe 3/4 of the hub's height is in the splines), but it's down as far as it can go......
[Modified by sackdz, 12:41 PM 4/26/2002]
Old Apr 26, 2002 | 08:44 AM
92sleepR's Avatar
New User
It should be fluch. Be sure you install the main shaft end bearing correctly, the thick side of the outer bearing race (with the serial # stamped into it) should be facing out, towards the end of the case.
Mike
Old Apr 27, 2002 | 02:03 PM
sackdz's Avatar
Default Re: My Tranny is binding up. (92sleepR)
Mike
Pefectly flush? Because I discovered I had the 5-R synchro sleeves switched, and now the mainshaft ball bearing sits nearly flush, a lot closer than before.... a nickel's thickness up. Is that right?
[Modified by sackdz, 6:04 PM 4/27/2002]
Old Apr 27, 2002 | 07:18 PM
owen_the_soyboy's Avatar
man, I had the same problem but I wasnt setting the c-clip correctly in the top half of the trannycase. are you sure thats not the problem?
Old Apr 28, 2002 | 03:07 AM
Rocket's Avatar
Default I think you got it
Here's a pic of a S80 mainshaft. The synchro hub, sleeve, and syncrhros go in "one" way on the 5th/Reverse section.
Old Apr 28, 2002 | 10:12 AM
sackdz's Avatar
Default Re: I think you got it (Rocket)
What's an S-80? Is that another tranny code like Y21? Which car?
ANyways, between your pic and another, I think I got it. I had the 5th and reverse synchro sleeves reversed and it was causing the bearing to sit 2-3 mm higher. Now it is lower, not completely flush, but neither is the one in this pic or the other. I think everything should be alrite now, I have to wait for a new bearing to come in because I took the case off and the bearing fell out and blew up.
Thanks for all your help guys.
Old Apr 29, 2002 | 09:28 AM
Rocket's Avatar
Default Re: I think you got it (sackdz)
S80 is a hydraulic GSR.
boostinnc
Transmission & Drivetrain
Jan 2, 2010 01:37 PM
unsungfate
Apr 24, 2008 01:57 PM
ALTERED4
Jan 30, 2003 11:46 PM
sackdz
Apr 21, 2002 12:07 AM
