Damn WTF this 3rd time i changed my fog light bulb.. any help? JDM front
Old Aug 13, 2006 | 01:46 AM
J.nguyen's Avatar
Default Damn WTF this 3rd time i changed my fog light bulb.. any help? JDM front
recently just sold my headlights and baught newer ones from a fellow HT member. blackhousing. well, first off passenger side fog light bulb went bad. replaced it. then driver side went bad. replaced it again with TWO brand new bulbs. then few days later, Driver side goes out AGAIN. WTF is GOING ON why they keep going out on me.. im using the Correct bulbs trust me the H3 bulbs. but wondering if it could be b/c headlights get foggy sometimes? b/c i noticed that these recent new headlights get foggy when its cold outside.. and i see some of the rubber seal has lil escape where air / moisture can enter.. so wondering if this can be the thing making my fog light bulbs die out.. or is it b/c of a grounding out issue or what is it!! i want to fix it before i run out of Extra h3 Bulbs..
Old Aug 13, 2006 | 02:26 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: Damn WTF this 3rd time i changed my fog light bulb.. any help? JDM front (Jesse.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesse. &raquo;</TD></TR><TR><TD CLASS="quote">recently just sold my headlights and baught newer ones from a fellow HT member. blackhousing. well, first off passenger side fog light bulb went bad. replaced it. then driver side went bad. replaced it again with TWO brand new bulbs. then few days later, Driver side goes out AGAIN. WTF is GOING ON why they keep going out on me.. im using the Correct bulbs trust me the H3 bulbs. but wondering if it could be b/c headlights get foggy sometimes? b/c i noticed that these recent new headlights get foggy when its cold outside.. and i see some of the rubber seal has lil escape where air / moisture can enter.. so wondering if this can be the thing making my fog light bulbs die out.. or is it b/c of a grounding out issue or what is it!! i want to fix it before i run out of Extra h3 Bulbs.. </TD></TR></TABLE>
bought.
and you should check to see how many volts they are getting and make sure its grounded properly and then see if the rubber seal is leaking, I imagine if moisture is getting in it might cause problems.
Old Aug 13, 2006 | 12:13 PM
J.nguyen's Avatar
Default Re: Damn WTF this 3rd time i changed my fog light bulb.. any help? JDM front (God.Loves.Ugly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by God.Loves.Ugly &raquo;</TD></TR><TR><TD CLASS="quote">bought.
and you should check to see how many volts they are getting and make sure its grounded properly and then see if the rubber seal is leaking, I imagine if moisture is getting in it might cause problems. </TD></TR></TABLE>
how do i do that w/o any electrical tools or whatever.
Old Aug 15, 2006 | 04:40 AM
tegSimple's Avatar
the water could very well be doing it. also, how are you handling the bulbs? do NOT touch the glass with your hands!
dgdarien
19
Apr 8, 2017 10:06 AM
bboixtc
Dec 9, 2006 04:53 PM
B18Cej1
Aug 20, 2005 10:53 PM
EXCoupe03
18
Feb 16, 2005 09:15 PM
