Headlights turn themselves on
Old Aug 12, 2006 | 09:25 PM
1991 DA's Avatar
Default Headlights turn themselves on
My headlights have been acting weird in my 1991 RS since I've owned it. When I turn on the car, about 5-10 seconds later the headlights turn on and are "half-way" on high-beams, I know this because the high beam light is partially lit up in the dash and they are noticeably brighter than the regular headlights. The headlights work like normal when switched on correctly with the lever, and the high beam works normally as well after the headlights are on from turning the lever. Does anyone know what's wrong? Thanks guys
Old Aug 12, 2006 | 09:33 PM
PrinceAli132's Avatar
Default Re: Headlights turn themselves on (1991 DA)
Maybe you have city lights
Ali
Old Aug 12, 2006 | 11:35 PM
blk_db2's Avatar
Default Re: Headlights turn themselves on (PrinceAli132)
mine do the exact same thing, but mine are suppose come on because I have drl (day time running lights) Canadian tegs came with drl stock...
is you speedo in km's
Old Aug 12, 2006 | 11:48 PM
1991 DA's Avatar
Default Re: Headlights turn themselves on (blk_db2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk_db2 &raquo;</TD></TR><TR><TD CLASS="quote">mine do the exact same thing, but mine are suppose come on because I have drl (day time running lights) Canadian tegs came with drl stock...
is you speedo in km's</TD></TR></TABLE>
No, the speedo's in mph and the VIN code says it's made in Japan
Old Aug 13, 2006 | 12:12 AM
blk_db2's Avatar
all DA's were made in Japan....
sounds like you have drl.... mine lights come on as soon as I release the hand brake... maybe the previous owner installed it...
Old Aug 13, 2006 | 02:34 AM
god.loves.ugly
Guest
Posts: n/a
I had a weird problem with my grounds that would cause my brights to turn off and on whenever I used my blinker.... and the little brights light in the cluster turned on also.... I don't know if it could be a wiring problem but you might want to check it out.
Old Aug 13, 2006 | 05:39 AM
Duane_in_Japan's Avatar
Default Re: Headlights turn themselves on (God.Loves.Ugly)
Pull the light switch assy from the steering column and look at the cicuit for burned spots.
Old Aug 13, 2006 | 09:16 PM
1991 DA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk_db2 &raquo;</TD></TR><TR><TD CLASS="quote">all DA's were made in Japan....
sounds like you have drl.... mine lights come on as soon as I release the hand brake... maybe the previous owner installed it...</TD></TR></TABLE>
Yeah I noticed that's exactly when the brights turn on, so my car must have DRL then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by God.Loves.Ugly &raquo;</TD></TR><TR><TD CLASS="quote">I had a weird problem with my grounds that would cause my brights to turn off and on whenever I used my blinker.... and the little brights light in the cluster turned on also.... I don't know if it could be a wiring problem but you might want to check it out. </TD></TR></TABLE>
Alright man I'll check my grounds and if that doesn't work then I'll take apart the steering column and see if the problem's there, thanks for the help guys
Morlow
10
Dec 15, 2010 06:28 AM
TheMoogly
Honda Civic (2001 - 2005)
11
May 13, 2007 11:25 AM
Cornering Artist
Honda S2000
Jan 26, 2007 01:30 PM
JinDIESEL
72
Oct 20, 2004 10:42 AM
diewX3
Honda Motorcycles
17
Feb 18, 2004 06:17 PM
