What's the difference between PG7 and PM6 ECUs
Old Aug 12, 2006 | 09:07 PM
baboracus's Avatar
Default What's the difference between PG7 and PM6 ECUs
I'm wondering if using a PG7 for a 1.6 DOHC ZC engine would be better than using the PM6. The car has a PM6 on it now but it doesn't seem to run as good as it should. It might be something other than the computer but I just thought it'd be better to have the computer intended for the DOHC 1.6 instead?
Old Aug 12, 2006 | 09:20 PM
crxnj's Avatar
Default Re: What's the difference between PG7 and PM6 ECUs (baboracus)
Well they're both the wrong ecu's but if i had to choose i would get the pg7 ..just be carefull wit that "redline"
you could always chip the pm6 with dohc zc fuel and timing maps though...external eprom versions are easier to chip
Old Aug 12, 2006 | 09:30 PM
ED7's Avatar
ED7
Default Re: What's the difference between PG7 and PM6 ECUs (Mr.speaker)
Pg7 would be better suited for your engine.
Old Aug 12, 2006 | 11:21 PM
Mach69's Avatar
PM7 would be best. Considering it is made for the ZC.
Old Aug 12, 2006 | 11:23 PM
Tyson's Avatar
pg7 is for a 88-89 integra. the DOHC ZC ecu is different. pm7 i think.
pg7 fuel curves are different than pm6. it gives an extra 300 rpm before ignition cutoff.
cant say if its better for the dohc zc, i imagine it would. i dont have a dohc.
but i can say it really doesnt give any more power to the d16a6 sohc, if not less hp. but it does give an extra 300 rpm.
Old Aug 12, 2006 | 11:50 PM
Spoon Sports's Avatar
Suit up
I know the pm6 redline cuts at 6600 or 6800
and I think the pg7 redline cuts at 7200.
I have a ZC; using a pm6 but if I put a pg7 it makes it run lean.
Old Aug 13, 2006 | 03:59 AM
661rex89si's Avatar
most people use the pg7 on dohc zc's and some say it works better than a pm6. if you want the right ecu theres the pm7 .
knightsef-eg
10
Jul 30, 2009 11:11 AM
BlueRex1020
Dec 2, 2006 12:49 PM
freshly boosted DOHC ZC
Nov 30, 2006 06:07 PM
89civich22
15
Dec 29, 2005 10:17 PM
cr-x si
10
Mar 20, 2003 07:54 AM
