Suspension & Brakes Theory, alignment, spring rates....
Brake Pad
Old Aug 12, 2006 | 06:17 PM
WalkerGSR1's Avatar
Default Brake Pad
When on the parkway I hit the brakes, and my steering wheel chatters. So i'm guessing i need new brake pads. i wanted to know when i get new pads can my slotted and drilled rotors be cut?
Old Aug 12, 2006 | 06:39 PM
chrisw85's Avatar
part of your wheel shimmy problem can be directly attributed to your current slotted and drilled rotors.
to alleviate this problem, get some blank rotors (autozone blanks are a very good value) and pads like Hawk HPS, a great street pad with some mild auto-x.
the steering wheel chatter/shimmy is runout on the rotor. could also be something suspension related if you dont feel any pulsing in the pedal--pusling in the pedal would be warped rotors or uneven pad deposits creating thickness variation.
Old Aug 13, 2006 | 08:39 AM
LudemanDan's Avatar
Yep. Just buy the cheapest solid brake rotors you can get and replace as necessary.
Old Aug 13, 2006 | 02:33 PM
WalkerGSR1's Avatar
The brakes where fine this just started to happen couple days ago. Aren't Slotted brakes better than the blanks?
Old Aug 13, 2006 | 02:36 PM
chrisw85's Avatar
Default Re: (WalkerGSR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">The brakes where fine this just started to happen couple days ago. Aren't Slotted brakes better than the blanks?</TD></TR></TABLE>
not necessarily. solid rotors have more mass, so they can deal with the heat better than something with less mass. bigger heatsink= in my book.
I dont think there are many if any pro SCCA or NASA honda racers that use slotted or drilled rotors. I've only seen solid/blank rotrs with the exception of those with specialized brake kits from companies like stoptech, baer, willwood, etc--even then you can order these rotors to be blank.
405hp
Honda Civic (2006 - 2015)
14
Nov 2, 2009 05:14 AM
Takashi1978
Apr 18, 2006 07:26 AM
jorge99hx
25
Dec 10, 2005 12:52 PM
bren1339
16
Oct 15, 2003 01:08 PM
95integrags-r
Jul 23, 2003 04:21 PM
