How-To question: DRL and low beam on at same time . . .
Greetings all,
Noob here, with a "why the heck would you want to do that" question....
How do I turn on the DRL and low beams at the same time. The plan is to replace the DRL bulbs (9005's) with something a little more yellow (fog style), with an end look of something like the 1st gen of the Lexus IS300.
I will likely replace the 9005's anyway ... I was considering the Nokya Artic Yellow (80watts).
Also, I can't kill the DRL's even if I put the E-brake on (like I've seen on other vehicles), so I was considering connecting a switch somewhere in the circuit to be able to manually kill it.
Any thoughts or suggestions?
patrickvertigo
14
May 28, 2009 10:16 AM
