where is the B18b stop revving
Old Aug 12, 2006 | 02:51 PM
motormike40's Avatar
Default where does the B18b stop revving
I just got a an Eg with an Ls swap in it, but the rev limiter was removed, I was wondering what rpm is dangerous to rev my motor?
Old Aug 12, 2006 | 02:53 PM
lVlemphizStylez's Avatar
Default Re: where does the B18b stop revving (motormike40)
anything beyond 7
Old Aug 12, 2006 | 02:54 PM
Ouch, i was taking it to 7.5 to a little over 8, it hit a point where the engine sounded like it had v-tec, that was when it went to 8.2.
Old Aug 12, 2006 | 02:56 PM
mike9571's Avatar
Default Re: (motormike40)
o my
Old Aug 12, 2006 | 02:58 PM
eh i guess its fine, It still runs strong. So no harm, no foul.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 &raquo;</TD></TR><TR><TD CLASS="quote">Ouch, i was taking it to 7.5 to a little over 8, it hit a point where the engine sounded like it had v-tec, that was when it went to 8.2. </TD></TR></TABLE>
may want to get that motor checked out now...Id be hard pressed to believe a b18b went to 8.2k with no valvetrain damage
Old Aug 12, 2006 | 03:22 PM
projectTeG's Avatar
Default Re: (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">may want to get that motor checked out now...Id be hard pressed to believe a b18b went to 8.2k with no valvetrain damage</TD></TR></TABLE>
ive mis-shifted twice on a ls and sent it to 8k and no problems, but constant abuse i would say there is some damage on both ends of the engine.
Old Aug 12, 2006 | 03:39 PM
I mean there are no noises, no smoke, no power loss. Im pretty sure its cool. Ill just rechip the thing to tach out at 7k.
Old Aug 12, 2006 | 04:26 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 &raquo;</TD></TR><TR><TD CLASS="quote">I mean there are no noises, no smoke, no power loss. Im pretty sure its cool. Ill just rechip the thing to tach out at 7k. </TD></TR></TABLE>
i had a friend with a d15b that was beat on....it to had no noise, no smoke, and no power loss and it blew without a sign. just because there is no noise it doesnt mean there isn't fatigue
Modified by projectTeG at 5:58 AM 8/13/2006
Old Aug 12, 2006 | 05:19 PM
DHutch's Avatar
wow ... hell of a time to ask that question ...
Old Aug 12, 2006 | 05:34 PM
7andaswitchblade's Avatar
Default Re: where does the B18b stop revving (518_GSR_kid)
Does it have a vtec head swap? That would explain it reving to 8.2k and sounding like it had vtec..
If not, yeah, I would never rev it that high again and pray you didn't break anything expensive
Old Aug 12, 2006 | 09:51 PM
PrinceAli132's Avatar
Default Re: where does the B18b stop revving (7andaswitchblade)
I would do a compression and leak down test just to check everything out.
Ali
Old Aug 12, 2006 | 10:01 PM
Rajin's Avatar
Default Re: where does the B18b stop revving (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">I would do a compression and leak down test just to check everything out.
Ali</TD></TR></TABLE>
I second that one.
You might have done something and not noticed.
Old Aug 13, 2006 | 07:58 AM
So thats pretty scary, maybe I get a once over done. Thanks.
Old Aug 13, 2006 | 08:37 AM
Danziver's Avatar
I dont think that was vtec you were hearing.
Keep it under 7k.
Old Aug 13, 2006 | 02:33 PM
auto-accessories-inc.'s Avatar
* B A N N E D *
Default Re: (Danziver)
i took my ls non rev limited motor past 8500 rpms several times nevr had any valve train problems, but di dcrack a block
Old Aug 13, 2006 | 06:49 PM
RJonathan's Avatar
I got a Free H23 once when I was building my H22 for my prelude, so we put the motor in and ran a chipped P75 and rev it to 8,000 constantly i would say like 5 to 6 times a week, by the time I pulled it out and did a compression check, #1 = 135, #2=140, #3=195, #4 =120... it was fun hehehe..
Old Aug 13, 2006 | 07:05 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danziver &raquo;</TD></TR><TR><TD CLASS="quote">
Keep it under 7k.</TD></TR></TABLE>
Yeah, it was probably the motor screaming in agony.
Old Aug 13, 2006 | 08:14 PM
b20powereDA's Avatar
Default Re: (Sleeper Style)
it is stop revvin when u let off the gas
Old Aug 13, 2006 | 08:25 PM
unknown0001's Avatar
Default Re: (b20powereDA)
Keep it under 7000 RPM. The b18b redline is either 6800 or 6900 but just under 7000
roberts88
Oct 31, 2007 08:35 PM
sayst
Jul 24, 2006 10:43 AM
scca ready
11
Dec 12, 2005 11:07 PM
civickid99
Jun 16, 2004 07:22 AM
t . b o z
May 27, 2004 05:26 PM
