Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
whats the little thingy on some roofs?
Old Aug 12, 2006 | 02:13 PM
sbosquet's Avatar
Default whats the little thingy on some roofs?
i've noticed that sqaure little thingy on the back of some civics and i was just wondering what it was? if its for navigation are you able to put it on if you go with a navi upgrade from just the factory stereo?
Old Aug 12, 2006 | 02:37 PM
al4t1gbundy's Avatar
Im guessing you would have to put it on if you upgrade
Old Aug 12, 2006 | 03:18 PM
modifyORdie's Avatar
Default Re: whats the little thingy on some roofs? (sbosquet)
are you talking about the built in antenna?
Old Aug 12, 2006 | 03:21 PM
sbosquet's Avatar
Default Re: whats the little thingy on some roofs? (modifyORdie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by modifyORdie &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about the built in antenna?</TD></TR></TABLE>
yeah thats it. is it a MUST for navi? and if so can you add it later?
Modified by sbosquet at 7:42 PM 8/12/2006
Old Aug 12, 2006 | 03:25 PM
i thought it comes on all cars because its for the radio? but im not sure. but if you dont have navi now, youll never be able to get the factory navi kit...at least i dont believe honda sells it...if you get an aftermarket navi kit and it needed one, it would come with it.
Old Aug 12, 2006 | 03:54 PM
TRAG's Avatar
pretty sure its for XM
Old Aug 12, 2006 | 06:29 PM
Type X's Avatar
Default Re: (TRAG)
Its for the XM NOT navigation.
Old Aug 12, 2006 | 09:02 PM
Demonis's Avatar
I think its retarded, because as far as i know, if you get the xm installed later, its antenna is hidden on your dash.... why didnt they just do that to begin with.
Old Aug 12, 2006 | 09:41 PM
Stein's Avatar
Default Re: (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">Its for the XM NOT navigation.</TD></TR></TABLE>
+1.
Old Aug 13, 2006 | 04:59 AM
n3twrkm4n's Avatar
Default Re: (Stein)
XM Requires a satelite link so it needs an external antenna of some sort. Most kits come with an external antenna unless you have a unit with an antenna built in and have it located under your window, then it might work.
Old Aug 15, 2006 | 10:50 PM
jonness's Avatar
So for that xm antenna, if I remove that, is there a hole?
(Thinking about removing it)
puffine
Acura NSX
Apr 9, 2007 10:01 PM
blaxican05
Jan 15, 2006 08:03 PM
MikeTV
Dec 28, 2004 08:14 PM
shift6th
Honda S2000
13
Mar 27, 2004 07:08 AM
B16A2-EM1
Jun 27, 2003 08:13 AM
