My D16y8 with P72
Old Aug 12, 2006 | 01:14 PM
JH4DC231's Avatar
Jay
Default My D16y8 with P72
I've got a D16y8 with a P72. Since I don't have vtec wired up, how much power should I be making?
Will there be a significant difference once I switch the ecu to a P28?
Old Aug 12, 2006 | 02:16 PM
tractiondeprived's Avatar
Default Re: My D16y8 with P72 (Mr. Famadico)
honestly you should be using a chipped p28 with y8 values, the ignition and fuel values are way different on the p72, the p28 would be a better match however the z6 motor the p28 is used on uses 16* of total timing whereas the y8 uses 12*, easy fix would be to have someone chip it and run uberdata or crome with the values for the y8 motor.
Old Aug 12, 2006 | 09:16 PM
JH4DC231's Avatar
Jay
Default Re: My D16y8 with P72 (tractiondeprived)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tractiondeprived &raquo;</TD></TR><TR><TD CLASS="quote">honestly you should be using a chipped p28 with y8 values, the ignition and fuel values are way different on the p72, the p28 would be a better match however the z6 motor the p28 is used on uses 16* of total timing whereas the y8 uses 12*, easy fix would be to have someone chip it and run uberdata or crome with the values for the y8 motor.</TD></TR></TABLE>
I completely understand this. Thanks for the reply, BUT that didn't answer my question at all.
Old Aug 12, 2006 | 09:50 PM
JH4DC231's Avatar
Jay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Famadico &raquo;</TD></TR><TR><TD CLASS="quote">Will there be a significant difference once I switch the ecu to a P28?</TD></TR></TABLE>
Will there be a siginificant difference in TQ and HP, is what I meant to ask.
Old Aug 12, 2006 | 10:02 PM
crxnj's Avatar
Will there be a siginificant difference in TQ and HP, is what I meant to ask.</TD></TR></TABLE>
you'll notice the car running much better,more repsonsive,no bogging,no more pig rich conditions ,etc....
since you dont have vtec and you're running wrong timing,and probably pig rich im going to have to say you're probably under 80whp (just an est,maybe lower)
Old Aug 12, 2006 | 10:10 PM
JH4DC231's Avatar
Jay
Default Re: My D16y8 with P72 (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">you'll notice the car running much better,more repsonsive,no bogging,no more pig rich conditions ,etc....
since you dont have vtec and you're running wrong timing,and probably pig rich im going to have to say you're probably under 80whp (just an est,maybe lower)</TD></TR></TABLE>
Thanks Mr. Speaker. If you were to estimate again, where would you think I should be at once I get the ecu?
Old Aug 12, 2006 | 10:12 PM
crxnj's Avatar
Thanks Mr. Speaker. If you were to estimate again, where would you think I should be at once I get the ecu? </TD></TR></TABLE>
well the p28 is still the wrong ecu but with vtec hooked up,,no cel's,normal working engine you'll probably get 90whp-100whp (again just an est)
Old Aug 12, 2006 | 10:30 PM
JH4DC231's Avatar
Jay
Thanks for the info.
TravisCadello
Apr 21, 2009 08:45 PM
user 98292739
Nov 23, 2007 03:11 PM
senate33
Apr 23, 2007 07:25 PM
EJ6_Hatch
Feb 1, 2007 10:08 AM
SFlCrx
Dec 3, 2006 06:58 PM
