CRX GSR mount issue...
I have my GSR in the engine bay but the driver side mount does NOT match what came with the kit.(others are fine) the driver side mount kit has staggered bolt holes while the engine part has bolt holes parallel bolt holes....Hasport website says the kit will bolt in any b16a or b18a....but to bolt in a b20 or b18c1 an extra "kit" is required....but they don't list the kit or where to find it....anyone help me out here?
http://www.hasport.com/Product...1.htm
.........The kit is designed to work with the B16A, B17A and B18A engines, but it will also work with the B18B, B18C, and B20B or Z with few extra parts.
...direct from the website.......HELP!!!!
To mount an engine other than a B16/B17 you'll need the driver's side mount from a 90-93 Integra.
It is the mount under the timing belt cover.
If you dig around on HASport's site, the info is there. That's where I found it when I had the same problem.
Down Shift Motoring
Feb 24, 2006 10:15 PM
w-fuck-ay
11
Aug 3, 2003 09:15 PM
