eg and da struts the same??????
let me refrase this........ does da struts fit and work on an eg ej........ i have some coilovers that came off an DA GSR..... they seem to be working fine..... so i dont see the difference in the coilovers and then the struts........
DA struts are longer than the eg struts. the coilovers in the back are going to make the car rear of the EG sit to high. Plus the DA struts are way smaller in diameter than that of the EG
ok i will give u all the info........
there is a 96civic coupe wit loweing springs. a 92da wit lowering springs. and a 95 civic coupe wit coilovers that came off a diff da. now were puttin the da lowering springs on the 95 and the coilovers off the 95 to the 96. and the 96 lowering springs to the da. should we change any springs around on the struts........please intelligent answers.....cause it is getting done in twenty mins
YOUR DA REAR SPRINGS ARE LONGER THAN THE CIVICS!!!!! EK to EG will work. DA to EG or EK will not work the *** end will be sky jacked. If you put the EK's springs on the DA the rear end will ride on the bump stops.
ok we figuered that da is compelety different so we just done the ek to ej....... the strut bottom on the ek is a whole lot smaller than the ej.......... so we ended up grinding down some of the lca on the ej....... worked fine other than that......... now lowered on skunk2's for 50 dollars.... they were basically brand new and he trading in the ek so he takin eveything off....... thanks for u alls help... if i wouldn't been a stubbord ******* and listened to u all we wouldnt of worked till 5 in the morning but i guess we learned the hard way....... thanks any ways
