Help with fast blinkers
Old Aug 12, 2006 | 08:12 AM
Yung DC4's Avatar
Default Help with fast blinkers
alright so i baught the car with already riced out fast blinkers.. i know its not the bulbs cause i changed them and it still blinks fast.. i read to check the relay.. but i can't get that damn thing out.. also i heard to check the grounds?? (black wire) do i check the back of every socket of the ground?? or where do i check.. appreciate it !
Old Aug 12, 2006 | 01:09 PM
enil01's Avatar
Default Re: Help with fast blinkers (Yung DC4)
I'd stick with checking the relay.
Old Aug 12, 2006 | 01:26 PM
aznsins88's Avatar
nto to jack the thread but im having light issues too. my turn driver side turn signals blink differently from the passenger side one. when its just on, only the outer side of it is on. but if i signal left it blinks on so im lost out of ideas. any helps please?!?!
Old Aug 12, 2006 | 02:05 PM
DC2 Mang's Avatar
there is probably a cut wire in your front bumper lense, try to locate it and re-attach the wire to the dual filiment bulb
Old Aug 12, 2006 | 05:35 PM
DHutch's Avatar
Default Re: (aznsins88)
If either your front or rear turn signal is out, it will cause the other to blink 2x as fast ... since the corner lenses often crack and get water inside, check the contacts inside the bulb socket ... these will often corrode due to the water leaving the circuit incomplete and the bulb out ... good luck!
Old Aug 12, 2006 | 05:45 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (518_GSR_kid)
I would check all sockets and make sure he did not change any wires. also make sure all the bulbs are in working order. Then work your way to the relay. It has to be one of thoses 3. If you live near by you can swing by and I'll help you figure it out. I am in so-cal too.
Old Aug 13, 2006 | 01:41 AM
ac_attak's Avatar
Did you check and see if the rear indicator bulbs are burnt out?
Old Aug 13, 2006 | 02:27 AM
god.loves.ugly
Guest
Posts: n/a
relay and the grounds. I had a loose ground and when I signaled it would turn on my wiper and blink fast....how? I have no idea. but I tightened it and it fixed it.
Old Aug 13, 2006 | 02:37 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Help with fast blinkers (God.Loves.Ugly)
A "free" way lots of people use to get those "hyper blinkers" is to pop out the lens assembly and swap the outer two of the three wires. Perhaps the previous owner did that. Try swapping the outer two wires that go into the lens assembly and try it.
jacreech777
Lighting
Aug 5, 2016 02:27 PM
Nerrej
Oct 21, 2008 09:35 AM
rkrone
14
Aug 26, 2006 06:38 AM
strongarm1731
Apr 10, 2006 06:43 PM
RiCeRTeG
Jan 27, 2005 10:58 PM
