Best way to install rear motor bracket when droping b series in?
Old Aug 11, 2006 | 08:55 PM
NAIIAWAH's Avatar
Default Best way to install rear motor bracket when droping b series in?
1.Should I mount the bracket to the engine and drop the engine then bolt it to teh
rear crossmember mount?
2.Should I install the rear bracket to the hasport rear crossmember mount and bolt it to the engine after engine is in the bay?
Old Aug 12, 2006 | 04:56 AM
2point2's Avatar
Default Re: Best way to install rear motor bracket when droping b series in? (NAIIAWAH)
this is a really good question!
Old Aug 12, 2006 | 05:01 AM
CRXBart's Avatar
Mount it to the engine, and then drop it in. Always line up, and slip the bolt through the rear mount first. Then move on to mounting the other two mounts.
Old Aug 12, 2006 | 08:26 AM
SiR Inspired ED7's Avatar
Default Re: Best way to install rear motor bracket when droping b series in? (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">Mount it to the engine, and then drop it in. Always line up, and slip the bolt through the rear mount first. Then move on to mounting the other two mounts.</TD></TR></TABLE>Correct. I've learned the hard way. I took like almost an hour trying to line up the bolts, not fun. Rear Mount is a bitch!
Old Aug 12, 2006 | 08:30 AM
mahatma's Avatar
Default Re: Best way to install rear motor bracket when droping b series in? (SiR Inspired ED7)
I did it the other way.....and wish I had seen this thread before I embarked
Old Aug 12, 2006 | 08:38 AM
NAIIAWAH's Avatar
Default Re: Best way to install rear motor bracket when droping b series in? (mahatma)
Thanks alot guys for the reply..I was looking at the thing a just wasnt sure which way is gonna be the easiest. Thanks for saving me time
xchikon
Jul 9, 2014 06:52 AM
Freemananana
Jul 5, 2013 09:46 AM
95dc2teg
May 1, 2007 10:35 PM
Bob_760
Sep 7, 2006 08:50 PM
lowboost civ
Mar 9, 2003 07:23 PM
