Fuel pump problem
To make it quick tried to start my car and it turns over but dosen't start so then checked to see if the fuel pump was priming and it wasn't checked 15 fuse and it was burnt, so i replaced it and it still doesn't prime, i ran it direct and it works
I just found out i have no spark my dizzy is only 3 monts old
Modified by NA EG6 at 11:08 AM 8/17/2006
I'm having the exact same problem...we gotta get this one figured out.
I resoldered the relay and still only once click and no fuel pump prime(second click.)
Put my relay in a friends car and it started just fine. Jumped terminal 1 and 7 and the pump primed no problem. Car is turning over fine.
See if there is power coming from the main relay(yellow/green wire runs to the fuel pump).
If there is power coming from the MR, check for power at the yellow/green wire at the fuel pump.
--if there is no power, check the contiutiy from the yel/grn at the MR to the yel/grn at the fuel pump. If there is no cont then you have a problem with the wire.
--if there is power at pump, but it does not run, check the ground. If the ground is good, the pump is probably bad.
i had the same problem. It turned out that everytime i turned the key it blew the ECU fuse in the engine bay. My problem was that there was a short in the engine bay. Does it keep blowing your Ecu FUSE????(very important)
i Have ran to this problem twice first with my crx and then with my eg crank no start and the fuel pump turns on. Replace the main relay it should fix it.
I tried that yesterday straight power to the pump and it works so has to be some were in the wiring were does the y/g wire to the relay come from
i had the same thing happen to me, i tried 3 main relays and nothing worked. It only clicked once, turned out my ecu took a dump on me, try a friends ecu to see if it still works
