Water pump serial number, timing belt (95 EX)
Old Aug 11, 2006 | 08:18 PM
BlakeOPS's Avatar
[deleted].
Old Aug 11, 2006 | 10:55 PM
RotaryBzzzz's Avatar
Default Re: Water pump serial number, timing belt (BlakeOPS)
1.) No. The only way you can tell if it's been replaced is if it looks 'cleaner' in constrast to the rest of the engine bay. ie the metal should look brighter in contrast to a dirtier engine block.
2.) 90k or 105k for newer belts. Someone else can clarify that.
Old Aug 12, 2006 | 08:11 AM
BlakeOPS's Avatar
Default [deleted]
[deleted].
Old Aug 13, 2006 | 07:20 AM
Duane_in_Japan's Avatar
do a search on this site, there are links to other sites. What other parts do you plan on changing too.
Old Aug 13, 2006 | 09:16 AM
v4lu3s's Avatar
RTFM
the best how to can be found in the Helm manual though the how tos in the Chiltons, haynes and mitchells are not bad as well.
Old Aug 13, 2006 | 10:54 AM
BlakeOPS's Avatar
[deleted].
Old Aug 14, 2006 | 03:32 AM
Default Re: (BlakeOPS)
Belts go by milage unless there is an oil leak from the cam or crank shaft seals, then the milage is lowered, is it worth not doing your belt, water pump and related belt items now and take a chance on doing it later plus a head removal and a valve job, the answer is on you based on your milage, it looks as though there is no oil leak but dont forget to change those seals anyways.
jttca
Jun 11, 2011 04:11 AM
Crazy3rdgen
Dec 22, 2010 12:28 PM
sanjiyan69
Acura TL, RL & ZDX
10
Dec 9, 2008 07:14 PM
freezerman
Aug 30, 2007 03:30 AM
rasta420
May 1, 2006 06:07 PM
