Maximum Boring Stock Sleeves Sleeves
What is the maiximum reliable bore you guys have seen on a CR-V block with a VTEC head?
Have you guys seen a 85mm bore CR-V block that is reliable?
-kenji
-kenji
About half the crv blocks I have seen had problems with 84.5 and 85.
What problems have you seen? It seems that they could bore bigger than that.
after seeing what i did, i would only sleeve a b18 if i wanted to use a larger bore piston
What we have found is that the stock sleeves on many b20 blocks are garbage... they can leak, especially when pushing the bore past 84mm
Akiraboy
Dec 15, 2005 10:08 AM
