My headlight socket melted....
well my headlight has been going in and out the past few days. and last night it went out and i got pulled over for it. thought it was just a loose connection but the socket is melted. anyone know why this would have happened?
stock bulbs from honda japan. headlights are 1 piece blacks bought new from honda japan
only driver side melted other 3 are fine
right now im looking for some JDM single peice headlights black housing and any advise or tips on them, i heard u have to change the wiring a little
by the way i have the fog light harmnest but dont have a switch or anything, do they turn on with the light when i turn it on at night or theres a switch that i dont know off cuz im new to 4 gen prelue, i saw that my fog light wires are with the signal turn light wires its just by it but corect me if its not. sounds stupid ha, sorry guys
holy ****, this almost happened to me. my damn headlight wouldnt work so i popped the hood to look at it...and the thing was smoldering! i got a new plug and rewired it and it was fine after that.
Your harness has a short in it. Happened to my JDMs also.
I just replaced it and have not had any issues since.
I could see mine sparking when I checked it out. There was a little bit of smoke too.
ive been having a foul burning smell coming from my engine bay hopefully it was the socket im gunna replace the socket tomorrow.
the harness or the socket has a short?
I have some Honda black plastic sockets and metal contact with several inches of wire on the shelf right now, common issue. Once the wiring gets a little cooked its time to splice in a whole nother set.
just wondering how much you paid for some brand new jdm headlights.
i was almost positive no honda dealership in the world kept stock of it anymore. unless you got lucky and bought it a few years back. kinda like the 94-96 foglight switch. very rare.
anyways i hope you don't have yours setup to where the high beams use both bulbs, that always puts more strain on things unless you know what you are doing.
i bought my lights from a guy who bought from honda of japan. he had documentaion showing it. he paid 800ish but sold to me for 250 since he wrecked his lude. but yes mine are wired up to when i turn my brights on both low and hi are on. thats how mine were setup when i bought the car. I simple just cut and spliced to hook up new headlights. and only my driver side low beam melted all others look and work fine. I changed out the socket today and so far its working fine.
well the high beams are supposed to only be the inside lights.
ppl just think since other cars uses the h4's dual filament as high/low that the prelude can too.
well i bought a whole front clip and used the harnesses to wire in my jdm headlights. they didn't wire that up from factory and i don't see it neccessary to run both as an "extra" set of high beams.
the stock jdm harness doesn't even allow for both to be on.
you can get a 5 pin relay and a h4 harness and wire up the lights so that the h4 bulb(outside bulb) is your high/low beam and then you can wire your inside bulbs(the normal highbeam) to be a DRL(daytime running light) or just another fog light. this way when you are driving on really dark roads at night with noone else on the rode you can have alot of lights.
wire them up up how you want.....you can just do the normal splice the wires where the old ones were, or take time to get the full potential out of your lights
That happened to me, seemed it was loose and it shorted somehow, melting stuff. I just made sure the connectors were very tight again (bent them a bit), whacked it back on and have not had any problems since. (JDM as well)
my headlights are very bright. when i installed them i double grounded the wires since there were 3 on the jdm ones and only 2 on the usdm. it made a significant difference i feel. and when i turn my brights on the road gets very well lit with all 4 lights. i just hope another socket dosent melt and potentially damages something that takes more then 2 bux and 5 mins to fix.
landon.alder
Nov 20, 2009 08:02 AM
m2s4drespecial
Honda Civic (2001 - 2005)
11
Sep 20, 2009 10:25 AM
eternity0114
May 8, 2004 05:51 PM
