GOT PROBLEM PLEASE HELP friend shifted from 3rd at redline to 2nd car wont start
Old Apr 24, 2002 | 09:34 PM
guyuenvy's Avatar
Default GOT PROBLEM PLEASE HELP friend shifted from 3rd at redline to 2nd car wont start
what can possibly be wrong if u misshift and overrevs?
Old Apr 24, 2002 | 09:36 PM
hungsteR's Avatar
Default Re: GOT PROBLEM PLEASE HELP friend shifted from 3rd at redline to 2nd car wont start (guyuenvy)
Bent valves
Old Apr 24, 2002 | 09:38 PM
Bob#455's Avatar
Default Re: GOT PROBLEM PLEASE HELP friend shifted from 3rd at redline to 2nd car wont start (hungsteR)
Bent valves
Ditto...take it to the dealer, and tell them what happened. If they cover it, fine. If not, tell your friend to suck it up and pay for his mistakes.
Old Apr 24, 2002 | 09:43 PM
hungsteR's Avatar
Default Re: GOT PROBLEM PLEASE HELP friend shifted from 3rd at redline to 2nd car wont start (Bob#455)
I think the proper course of action would be a compression and leak down test right?
Old Apr 24, 2002 | 09:57 PM
1GreyTeg's Avatar
CORRECT!
Sounds like he broke that thing. Get a flatbed and take it to a dealer or a reputible shop.
Good luck,
A.
PS It always amazes me how many people mis-shift like this or the 4-2 is another stumper. It is truely amazing... And Really bad for the car, not like a toasted clutch or anything...
[Modified by 1GreyTeg, 11:04 PM 4/24/2002]
Old Apr 24, 2002 | 09:59 PM
B2FiNiTY's Avatar
Man...why does this happen so much!!!
Old Apr 24, 2002 | 10:14 PM
hungsteR's Avatar
Default Re: GOT PROBLEM PLEASE HELP friend shifted from 3rd at redline to 2nd car wont start (B2FiNiTY)
That's why I really don't like to let other people drive my baby. The more and more I hear of all these "other" driver mistakes makes be want to become an ******* and not let other people drive her.
hung - who still lets people take her for rides, for now...
[Modified by hungsteR, 1:15 AM 4/25/2002]
Old Apr 24, 2002 | 10:21 PM
GokuSSJ4's Avatar
imagine how often it happenss on the RSX , to even the dealer advice people the danger of down shifting
Old Apr 24, 2002 | 10:33 PM
jet's Avatar
jet
New User
what's with R owners letting their friends drive their R straight to the repair shop lately??this is the second same incident i've read in like two weeks people..pls use discretion!....sorry man-good luck
Old Apr 24, 2002 | 10:37 PM
George H's Avatar
Default Re: GOT PROBLEM PLEASE HELP friend shifted from 3rd at redline to 2nd car wont start (jet)
Bent Valves = $
Engine Rebuild = even more $
Learning To Shift Properly....Priceless
Sorry to hear about the car.
Old Apr 24, 2002 | 10:42 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: GOT PROBLEM PLEASE HELP friend shifted from 3rd at redline to 2nd car wont start (KANJI)
You're fucked.
GokuSSJ4's Avatar
Bent Valves = $
ah ! classic moments
Old Apr 24, 2002 | 10:58 PM
sgT's Avatar
sgT
This is why I set my motor up so that no valves will bend even on a misshift.
Old Apr 24, 2002 | 11:03 PM
SlayANT's Avatar
Default Re: GOT PROBLEM PLEASE HELP friend shifted from 3rd at redline to 2nd car wont start (sgT)
shifting from redline 3 to 2nd.. ur engine is pretty much toast. Bring it to a shop and hopefully most of it is still in one piece. Next time, before u let ur friend drive ur car, make sure he knows how to shift.
[Modified by SlayANT, 12:04 AM 4/25/2002]
Old Apr 24, 2002 | 11:04 PM
goern-R's Avatar
How do you set a motor up to do that?
Old Apr 24, 2002 | 11:08 PM
onyx00's Avatar
Yeah, I built my motor without valves so I can rev so whatever RPM I want...
Old Apr 24, 2002 | 11:17 PM
sgT's Avatar
sgT
Default Re: GOT PROBLEM PLEASE HELP friend shifted from 3rd at redline to 2nd car wont start (goern-R)
I've explained this many times.
Basically the cam timing doesnt change. Hence, valves dont bend.
Old Apr 25, 2002 | 03:46 AM
TyperDude27's Avatar
Default listen to this story about a MISS SHIFT!!!!
The same thing happened to my friends 97 ITR. When he just got the car, he had put a different shift ****. You know those type that you tighten with an screw to the stick shift?? anyway....
So here we are at a red light (way back in 1997!!) and some guy pulls up in a 5.Slow So at the green, my friend just revs up his ITR, and off we were.... 1st gear...2nd...gear...8800rpm... 3rd gear...8800rpm... then he goes to shift to 4th gear, and since my friend shifts fast like lightening, he ripped off the shift **** off the stick shift which was tightened hard enuff.... so here we are, 8800rpm, 90+mph, mustang up our ***, my friend is in a total panic grabs the stick shift, and puts it, in what he thought was 4th gear... but it was really 2nd gear.......ALL YOU HEAR IS...
OUUUUUUUUUUUUUUUUUWWWWWWWWWWWWEAAAAAAAAHHHH....
no joke, the tach rpm need flies straight past 10000, i mean...12000RPM or something like that, the needle went straight down, only for like 2-3 secs, ....
anyway...turns out, he blew the clutch, had to overhaul the tranny, but the motor was A1..... no problem with the motor what so ever, i was really surprised, blown tranny, but motor ok.. Let me tell you, he has is stock stick shift back on his car!
bb62o3
Jul 5, 2008 12:56 PM
97blacklude
Dec 31, 2007 05:27 PM
JoeyBallzSI
35
Jan 8, 2004 12:49 PM
FusionITR
Dec 12, 2001 07:28 AM
ActiveAero
Nov 25, 2001 08:40 AM
