Lower ball joint castle nut wont budge. How to make a removal easy?
Old Aug 11, 2006 | 05:18 PM
integra15's Avatar
Default Lower ball joint castle nut wont budge. How to make a removal easy?
I have a 2 foot breaker bar on it and it still wont budge. I am putting all my weight into it and it wont move.
How do the mechanics do it so easy. I already tried my air tools too.
Old Aug 11, 2006 | 05:31 PM
soundbomber's Avatar
Default Re: Lower ball joint castle nut wont budge. How to make a removal easy? (integra15)
i'm sure you've done it, but you've removed the cotter pin right?
Old Aug 11, 2006 | 05:34 PM
integra15's Avatar
Default Re: Lower ball joint castle nut wont budge. How to make a removal easy? (soundbomber)
Yep, I did. I am going to let it soak with wd40. If anybody has any pointer please post them up.
Old Aug 11, 2006 | 05:52 PM
Rudaluda's Avatar
on the side of the ball joint theres a metal piece that sticks out beat that with a big hammer. or ball joint pickle fork. but you say the castle nut wont budge maybe its striped mine was today i had to cut it with an air chisel.
Old Aug 11, 2006 | 06:18 PM
integra15's Avatar
Default Re: (Rudaluda)
It was i bit rusted so I got the whole nut submerged in a bowl of wd40. We shall see tomorrow who will win lol
Old Aug 11, 2006 | 06:41 PM
korney's Avatar
Default Re: (integra15)
hahaha...I broke two breaker bars...trying to get mine off (luckly it was auto zones' and not mine LOL) ...I even torched it... still wont bugde. I just ended up taking it to the shop and have them take it off... they used a tourqe gun or whatever to take it off... some thousand ft/tq....gun... Just have a shop do it...sure it may cost money, its better than breaking things on your car...
Old Aug 11, 2006 | 07:38 PM
xxmastermindxx's Avatar
Default Re: (korney)
this past weekend i had the same exact problem, both the castle nut and the spindle nut, i had a 4 foot pipe on the end of a 3/4" foot and a half long ratchet on that thing and it would not budge, even with two 300 pound fat guys on it. air tools didnt do a thing to it either
well, the castle nut eventually got stripped. and the only way i saw it coming off was with the air chisel. if you've got one, try and use it, just dont mess up what its bolted to
Old Aug 12, 2006 | 03:06 AM
vinuneuro's Avatar
Just keep making your breaker bar even longer with more pipes. It WILL eventually break with the proper amount of torque.
Old Aug 12, 2006 | 09:13 AM
cr0c0's Avatar
Default Re: Lower ball joint castle nut wont budge. How to make a removal easy? (vinuneuro)
Either that, or one of the pipes will slip, causing the rest of them to start flying...
Old Aug 12, 2006 | 05:47 PM
mercfwd2's Avatar
wow mine came right off even with a good bit of rust luck of the draw I guess.
Old Aug 12, 2006 | 09:19 PM
NewOrleansH22's Avatar
Default Re: Lower ball joint castle nut wont budge. How to make a removal easy? (mercfwd2)
I/R 1/2" titanium inpact gun FTW. only thing i found that could get my crankbolt loose. (it was stronger than the 1" inpact that i had to borrow from a friend that works on semi's.)
Old Aug 12, 2006 | 09:29 PM
CGags13's Avatar
have you checked that the ball joint isnt spinning in the knuckle
Old Aug 12, 2006 | 09:40 PM
mgags7's Avatar
pardon my retarded brother ^^, its obviously not turning at all according to the OP
like vin said, get your pipe out and jack it
Old Aug 12, 2006 | 10:04 PM
CGags13's Avatar
Default Re: (mgags7)
yes pardon me i overlooked the part where you said it didnt turn..man now i feel rookish
Juans_MX3
42
Jul 10, 2021 04:38 PM
pliskin679
May 8, 2009 01:02 PM
PatrickGSR94
Suspension & Brakes
Jun 9, 2007 10:00 AM
Chiller
Mar 29, 2005 03:23 PM
gumbybum
Jan 31, 2003 11:11 AM
