how the hell do you clean the gauge cluster lense.
so i took off my gauge cluster and remove the lense to try to clean it. I use some windex, turns out that was a bad idea because it started developing spots, then i try some dish washing detergent and it makes it even worse. anybody know how i can fix this?
well the front lense has become very fuzzy and has alot of tiny scratches. i'm thinking about using some high grit sand paper to sand it out to clean it up do you think that would be ok?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR »</TD></TR><TR><TD CLASS="quote">Did you try wetsanding when you used the 2000 grit? I sure hope so.</TD></TR></TABLE>
yeah i did wetsand with 2000 grit. it only made it worse. I'm going to try some rubbing compound.
http://www.acuraparts247.com/p...ch=no
#16, $25. It's worth it, I replaced mine and it made it much easier to see.
wow i had the exact same problem u had. Use Windex and yes its a very big mistake if u do use it. Same results with bunch of ugly spots. I use plastic polish, not sure what brand it is because my sister got it from her school. Usually plastic polish has a small amount of grit that actually sands down the plastic. End results, looks like brand new to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 »</TD></TR><TR><TD CLASS="quote">Since you wetsanded it now you have to buff it.</TD></TR></TABLE>
Lol, and I thought they were suppose to come out shiny, n slick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDC4 »</TD></TR><TR><TD CLASS="quote">wow i had the exact same problem u had. Use Windex and yes its a very big mistake if u do use it. Same results with bunch of ugly spots. I use plastic polish, not sure what brand it is because my sister got it from her school. Usually plastic polish has a small amount of grit that actually sands down the plastic. End results, looks like brand new to me. </TD></TR></TABLE>
yeah seriously. let that be a warning to you all, do not use windex on your gauge cluster lense.
.jacob
11
May 27, 2003 01:45 PM
