problem with fuel maybe?
i drove my teg for the 1st time in 6 months since i bought my TSX and it ran fine but after when i was leavin my boys house it wouldn't want to start i wasn't hearing the fuel pump an i would hear it cuz its the walbro 255 hp. but not too long after work today i went bak to the car an it started up fine on the first crank. the fuses was good but what else could've been the problem? i want to take the car out to the track next w/end but not sure if it will run into problems. the only thing i could tink of was maybe cuz of the fuel being old. well its a JDM H22 i got on the car jus for some info but if anyone can help out i would greatly appreciate it.
Main relay, the contact points are weak and tend to not make contact in extreme heat. It is located by your left knee behind the coin tray(When you sit in the drivers seat). If you pull that out you should be able to see a grey box and it is held in by a 10 mm bolt. You can open the box but a new one is around 50$. I am 99% sure that is the problem
thanks alot for your help i had the relay replaced less than a year ago and it turns out to be the fuel pump. i found out that the Walbro Pumps only last about a yr or so and i've had it for bout 2 yrs now. so i already got one. just really surprised thats all they last for, i would've expected more reliability than just 2 years.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crix868 »</TD></TR><TR><TD CLASS="quote">thanks alot for your help i had the relay replaced less than a year ago and it turns out to be the fuel pump. i found out that the Walbro Pumps only last about a yr or so and i've had it for bout 2 yrs now. so i already got one. just really surprised thats all they last for, i would've expected more reliability than just 2 years. </TD></TR></TABLE>
How sad...shakes head...Walbro has been around for a good while now.
WELL JUS TO DO A REPOST IT WASN'T MY FUEL PUMP SO I SOLD IT BACK AND IT TURNED OUT TO BE ANOTHER FUSE THAT WAS ATTACHED TO THE FUEL LINE RUNNING INTO THE FUEL PUMP. WHEN WE RE DID ALL THE WIRING THE SHOP HAD ADDED A FUSE TO THE WIRING AND THAT FUSE ACTUALLY CRACKED BUT WOULD STILL WORK IF IT WAS TOUCHING AND SHUT OFF THATS Y MY CAR WOULD BE WORKIN ON AN OFF
QUiKSR20
Jun 24, 2004 01:28 PM
