Rear Disc Conversion-95 ex
I tried searching for this but came up with 0 hits.
Anyone seen a post of website where I can get a write up on upgrading my 95 EX rear brake drums to disc brakes?
Thanks
Thanks
Here, let me be more specific
go here for your FAQ's
here's a writeup on a disc swap for an eg, should be pretty much the same for your car, and here's another one. Same **** even though it's a hatch.
here's another....and another...
They're all over the place, just search the FAQ and find one that you like...
EDIT:
PS: Then you obviously didn't use the search feature too well then did ya? Not to mention the FAQ forum is in the sticky's that you're supposed to read before posting in this forum. So you didn't follow the rules on that - then you failed to use the search properly...jeez...you're a mess.. :-P. Just ****** with ya...though it is true..they're all in stickies and if you searched right it shoulda shown 'em... Anyways, good luck in your swap.
EDIT:
if you are search-deficient, ALWAYS check out the second thread in this forum. it contains FAQs covering just about everything you're going to do to the car.
thanks all, I guess I used too many parameters in my search...
No, just came back to this forum after two years--did not remember the FAQ section but will use from now on.
not that difficult...make sure you get the brake hoses in the rear, e-brake cables needed swaped....master cylinder, if you have the small one, brake booster maybe and then porportioning valve, if you wanted to
