Suspension & Brakes Theory, alignment, spring rates....
Question regarding the sub frame and asr kit (gsr)
Old Aug 11, 2006 | 01:15 PM
jthm's Avatar
Default Question regarding the sub frame and asr kit (gsr)
I know there have been a lot of posts regarding the asr kit and the weakness of the sub frame with larger sway bars, but my questions are somewhat different.
Does anyone know if the displacement of the sway bar a half an inch or so back with the asr kit has any negative effects to the original design?
Where exactly is the weak part of the sub frame, and would it not be easier to just reinforce it by reinforcing the welding?
Old Aug 11, 2006 | 08:37 PM
JunY's Avatar
Default Re: Question regarding the sub frame and asr kit (jthm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jthm &raquo;</TD></TR><TR><TD CLASS="quote">I know there have been a lot of posts regarding the asr kit and the weakness of the sub frame with larger sway bars, but my questions are somewhat different.
Where exactly is the weak part of the sub frame, and would it not be easier to just reinforce it by reinforcing the welding?</TD></TR></TABLE>
I haven't got my ASR brace yet but I could give you a little insite on the subframe issue. On a Bigger diameter rear sway bar, I had a Progress 22mm(original/teal) installed for about 5~6 years, until the subframe started showing some hair line cracks(getting it fixed soon). The sway bar on mine was bottoming out on the rear LCA's and was literally 'pushing' the lower end of the subframe forward because of the force(see the pic below of what I mean....) causing it to rip a little.
But for the people that use other Sway bars that are even stronger, without a brace, the shear strength of the sway bar puts alot of stress on the subframe and rips a hole where the D-brackets are mounted. The problem starts where the bend in the subframe is(around the inner mounting location bolt of the LCA's).
To answer your question of reinforcing it, it is possible "If" you remove your subframe and weld in a gusset on the inside, like the 99~00 Civic Si rear subframe, but that's very costly and pain in the *** to fix. Basically, the ASR brace is a 'stress releaving/tie bar/reinforcement' brace for the subframe.
And to answer the mounting location of the sway bar....you might want to refer to ASR's site. There's a "FAQ" section on it.
http://www.ASRparts.com
To be more specific, ask Charleston (SN: "CivicFerio" on this site).
I hope my insite helped a little.
Old Aug 11, 2006 | 08:42 PM
jthm's Avatar
Perfect, thanks a lot.
Old Aug 11, 2006 | 08:45 PM
JunY's Avatar
Default Re: (jthm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jthm &raquo;</TD></TR><TR><TD CLASS="quote">Perfect, thanks a lot.</TD></TR></TABLE>
No Problem. Just ask Charleston on specifics on prevention.
On1wheel
Nov 10, 2018 06:59 AM
HipHapa-Eg
Suspension & Brakes
Dec 7, 2009 03:44 PM
teddy_dc2
Suspension & Brakes
May 27, 2007 06:39 PM
odogg726
Feb 21, 2007 09:22 PM
b18bfreak
May 28, 2002 05:54 PM
