car wont start with key
Old Aug 11, 2006 | 12:43 PM
tampabitches's Avatar
Default car wont start with key
need help my car wont start with the key i jumped the clucth swicth and still doing it. i dont wont to run a switch to start my car so please help
Old Aug 11, 2006 | 05:42 PM
b16civster's Avatar
Default Re: car wont start with key (tampabitches)
can you get the car to run at all
Old Aug 11, 2006 | 08:06 PM
the car runs fine but i have to jump the soliond on the starter to get the car to start but the starter is good and i dont want to run a switch to start it
Old Aug 11, 2006 | 11:47 PM
dseriesdrag's Avatar
Default Re: (tampabitches)
Check the starter solenoid!! It should click when you turn the key to the on position I believe.
BTW, its down by the hood release.
Old Aug 12, 2006 | 02:50 AM
ZCcivicBOI's Avatar
a problem that i had with my car the key turned on and everything but it diddnt start and i found out that, on the back of the ignition is a white switch that bolts to the ignition with 2 screwes on mine one of the screwes came out, and so when i turned the key on it diddnt turn that switch all they way so check that...
Old Aug 14, 2006 | 01:34 PM
please someone help can't solve the problem tried everything i could think of
Old Aug 14, 2006 | 02:56 PM
89hatcher's Avatar
i believe its your clutch switch. the rubber thing that pushes the switch must have broken off you can tape a coin to the pedal or glue one on like a nickel. hope that helps. cause thats the same thing that happened to me.
EF_Nina
Sep 30, 2011 02:15 AM
itslogz
Apr 4, 2010 08:21 PM
88 EF Hatch
Jun 27, 2009 06:52 PM
Auby
Mar 3, 2009 01:50 PM
buzlink
Aug 6, 2001 02:11 PM
