Suspension & Brakes Theory, alignment, spring rates....
Are these Integra LS sway bars a direct bolt on to a 92-95 Hatch? *Pic*
Old Aug 11, 2006 | 09:42 AM
Fuster_Cluck's Avatar
Default Are these Integra LS sway bars a direct bolt on to a 92-95 Hatch? *Pic*
I am finally getting around to install my suspension componets from a salvaged LS I picked up about 16 months ago. I installed the rear trailing arm assembly which is about complete and would like to install these sway bars when all said and done.
I can not even remember if both came off the back or one was from the front
The car is a 95 Civic VX and the salvaged car was a 94 Integra LS. Would like to know if both are direct bolt ons and also if both are for the rear or one is for the front.
Here are the bars:
I will be prepping/painting before installing them
Thanks for any help!
Old Aug 11, 2006 | 10:31 AM
Voyage34's Avatar
Default Re: Are these Integra LS sway bars a direct bolt on to a 92-95 Hatch? *Pic* (Hybrid93Hatch)
you have pictured both a front and rear bar, the top thin one is a 13mm (i think, some years of LS integra had a 13mm rear and some had a 14mm rear, i dont remember which years used which) rear, and the thick bendy one is a 22mm front bar.
they should bolt directly up assuming you have the proper lower control arms. IIRC the vx didnt come with a front bar stock, and because of that im assuming its front lca's aretn designed to accept sway bar endlinks.
similar situation in the rear, where your lca's arent drilled to accept a swaybar endlink
other than the lca's, the front endlinks (slhondaparts.com part#'s 51312-SR3-000 RUBBER STABILIZER END, 90112-SE0-000 BOLT, FR. STABILIZER, 90362-SF1-003 NUT, SELF-LOCK) and the D-brackets (51308-SR3-000) to mount the bars to the frame, i think you should be set.
Old Aug 12, 2006 | 01:06 PM
Heinz57's Avatar
Default Re: Are these Integra LS sway bars a direct bolt on to a 92-95 Hatch? *Pic* (Voyage34)
You need LCAs that will accept a sway bar for front and back.
If rear LCAs came with those rear trailing arms you swapped, then you should be good on that.
here are two how-to's i did for my 92 VX.
Rear: https://honda-tech.com/zerothread?id=1564967
Front: https://honda-tech.com/zerothread?id=879554&page=1
Prudz_lude
Jan 17, 2008 03:57 PM
tortis
Suspension & Brakes
Nov 3, 2007 04:10 PM
realis9
Apr 13, 2007 01:32 PM
shyboi4u
May 19, 2006 02:08 PM
0gsR
Apr 28, 2002 09:43 PM
