Pass window won't go up after I was stupid and cut a wire I was unsure about.
today i was messing with the wire harness on the drivers side in my cousins 93 accord and now the passengers window wil not go down nor will the drivers door stay locked. help please!!!! i think its a broken wire. if so how do i fix it?
i cut the blue/green wire but i put it back together. the window still does not go up
i actually thought that the wire i cut was a wire going to one of the door speakers but i dont think so now. i never finished to find out. i cut the blu/grn wire thats under the carpet on the drivers side beside the seat. i was going to tie the wire in to my head unit to elimnate the bose amp. now im stuck
Dont use a connector, those seriously never work. Especially on such a small wire. Just splice the wire & connect it with either electircal tape, or sodder it (if you know how) & see if that solves the problem.
Never just use electrical tape, always solder and tape. Wire connectors should work fine, I do car audio installations including alarms and the like all day, never had a problem using a butt connector if it's the proper guage for the wire but soldering is probably your better bet for what you're trying to do. Not sure why you would cut the wire under the carpet and not at the amp or at the speaker though...either way, GL. NEVER JUST TAPE A CONNECTION!!!! lol
If the cut wire is not long enough to connect the ends you will need to SPLICE a little piece of the same gague wire between them. Use butt connectors. I remove the hard plastic from them and than crimp and solder them. After that a good tape job finishes the connection.
Rayz_Si
May 10, 2008 02:29 PM
GSRaCeRbOI
Audio / Security / Video
Jun 17, 2002 07:31 PM
