Leak from....a motor mount???
Old Aug 11, 2006 | 05:03 AM
PhoebeusFenix's Avatar
Default Leak from....a motor mount???
Hey everybody, need some quick help. I am changing my engine oil at the moment and I got under there to check things out and I had recently replaced my suspension bushings on my LCA's with polyurethane bushings. So I was feeling around and I notice on the right LCA there is LOT of grease, not oil but thick, thick black grease. I followed it up and it looks as if it is coming from the motor mount bolt. Is this possible? I cannot find any other place it could be coming from. Any ideas?
BTW- Car is a 93 dx hatch w/ b16a
Old Aug 11, 2006 | 05:16 AM
miahmouse's Avatar
Default Re: Leak from....a motor mount??? (PhoebeusFenix)
errr... on the LCA... somewhere near a cv joint perhaps? I'd check your cv boots...
edit:
it doesn't have to be fully torn, I've had a couple "perforate" and at speed they sling tons of little speckels of grease everygoddamnwhere
Old Aug 11, 2006 | 05:22 AM
That may make sense. When I was replacing my bushings the axle on that side came loose from the cv joint...Ill check her out! Thanks!
Old Aug 11, 2006 | 08:09 AM
del_slow420's Avatar
Default Re: (PhoebeusFenix)
the grease is coming from your axle boot just squesse it and im sure u will c it leak out...
Old Aug 11, 2006 | 08:33 AM
u_gnit's Avatar
where else would grease be coming from? it should be your axles, (cv boots)
SlickC95
May 23, 2012 09:35 PM
C_Rock77
Sep 5, 2008 09:32 PM
Ruben19
Suspension & Brakes
Oct 24, 2006 01:06 PM
themilman
Jun 8, 2006 08:20 PM
UltimX
Suspension & Brakes
Nov 1, 2005 02:21 PM
