front strut bar question
Old Aug 11, 2006 | 02:46 AM
liftandcut's Avatar
Default front strut bar question
Any of you guys ever have a problem with your strut bar clearing the the throttle body? Mine is right on it and I'm afraid that might cause a problem in the future. I originally wanted to use spacers but it seems like the strut is hitting the underside of the hood already.
Old Aug 11, 2006 | 06:07 AM
PrinceAli132's Avatar
Default Re: front strut bar question (liftandcut)
What year is your teg? What strut bar are you using? And do you have a swap in there?
I probably won't be able to help, but this info will probably help others.
Ali
Old Aug 11, 2006 | 06:10 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: front strut bar question (PrinceAli132)
i would like to know which bar you are using
Old Aug 11, 2006 | 01:34 PM
liftandcut's Avatar
Default Re: front strut bar question (HOLLAAAAAA)
It's an AC Autotechnic bar. I had great results with one of their short ram intakes so I decided to go with them on the strut bar. Guess the joke's on me. Has anyone else ever had a problem with the strut bar hitting the hood? If not, let me know which brands fit well under the hood of a '91 Teg and I'll go scoop one up. Thanks.
Modified by liftandcut at 3:08 PM 8/11/2006
Old Aug 12, 2006 | 10:48 PM
gsrtim's Avatar
Also had the same strut bar. It was a little too close for my liking but I never had a problem with it.
Old Aug 13, 2006 | 10:31 AM
liftandcut's Avatar
Default Re: (gsrtim)
I had to take the bar off because since it was flat on the throttle body it was not allowing the engine to vibrate. Consequently, the steering wheel and the rest of the car were shaking. I tried to put spacers under the ends of the strut bar but it didn't raise it up off the throttle body. If you were able to use the Autotechnic bar, maybe it's something with my car. You have a '91 Integra as well? Sux. Now I have to try to sell this bar.
Old Aug 13, 2006 | 10:34 AM
b20acura's Avatar
i had the same problem with the type r one, but i put like 3 washers under it and i dont have the problem anymore.
Old Aug 21, 2006 | 10:59 AM
liftandcut's Avatar
Default Re: front strut bar question (b20acura)
Yeah, I tried the washers but it didn't help. Guess I'm out a few bux. Any opinions on which brand of bar I should buy next for my '91 Teg?
Old Aug 21, 2006 | 11:38 AM
gogogomoveit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem with the type r one, but i put like 3 washers under it and i dont have the problem anymore.</TD></TR></TABLE>
I have no problem with ITR bars whatsoever. Stock fit and I have a gsr
Old Aug 21, 2006 | 12:45 PM
BlueIntegraBoy's Avatar
Default Re: front strut bar question (gogogomoveit)
No problem with an ITR bar with a B18C in an EG.
MechEng
May 29, 2011 06:49 PM
s2k_boy
Honda S2000
Oct 4, 2005 07:05 PM
fresh99si
Mar 25, 2003 03:13 PM
eight-six
Nov 9, 2001 06:58 PM
