I Need Help!!!!!!!!!!!
Ok so i swapped an LS into my 95 hatch and had it running for about two months and out of the blue it just quit working.....maybe you can help me out any suggestions would be nice, thanks for your time
engine turn off while driving
engine wont start
did u do any maintance when you swap the motor ex. belts
please be more specific
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS_92_HB_TX »</TD></TR><TR><TD CLASS="quote">Ok so i swapped an LS into my 95 hatch and had it running for about two months and out of the blue it just quit working.....maybe you can help me out any suggestions would be nice, thanks for your time </TD></TR></TABLE>
engine wont start
sorry im tired, the engine wont start, but i know that the starter and battery is good cause i just bought ithem like 2 weeks ago, i replaced the fuel pump, flushed the motor, new plugs and wires, an LS harness and Ecu, new belts(timing and alternator) had new main and rod bearings put in. my check engine light isnt on, i just can figure it out
so you say the starter is good.... does it crank??
when/if it cranks, does it spark?
do you hear the fuel pump prime?
Check fuses, grounds and connections...
Yep, you need to pull a sparkplug out, ground it, crank the engine over and see if your getting spark.
Also, when you turn the key to the "on" position, listen for the fuel pump priming. It should turn on for a few seconds and then shut back off.
Let us know the results so we can better help you with your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse »</TD></TR><TR><TD CLASS="quote">so you say the starter is good.... does it crank??
Check fuses, grounds and connections...</TD></TR></TABLE>
answer this, i thaught it was basic knowlege so start with theese things. a motor is pretty simple if you break it down
crazydominicanman
Dec 4, 2009 10:27 PM
