Once a clutch slips, its done right?
Old Apr 24, 2002 | 08:17 PM
2fast4u's Avatar
Default Once a clutch slips, its done right?
I was dragging tonight and when i threw second and let go of the clutch is slipped to 8k and then i let go and gave gas again it was fine.
So on the way home i pushed it a little and it seemed fine but only grabbed at the top of the pedal, so I guess is done right?
What is the cheapest way out for me to get it back on the road? but not with chitty parts...
Or do i try acura and see what they say?
Old Apr 24, 2002 | 08:29 PM
RacerXI's Avatar
Default Re: Once a clutch slips, its done right? (2fast4u)
No, not necessarily. You've worn a "spot" as we'll call it in the disc. A few weeks back i slipped my clutch out and 4K only to watch the RPM's move through 3 gears and the car barely moving along at 15mph. Be good to the clutch for a few days and the normal feel should come back. HTH.
Old Apr 25, 2002 | 01:52 AM
MyYellowHonda's Avatar
New User
Default Re: Once a clutch slips, its done right? (RacerXI)
If it's okay, could someone please explain to me what it means by "Slipping" the clutch? How do you know if it's slipping etc...
Old Apr 25, 2002 | 04:54 AM
typer_801's Avatar
Default Re: Once a clutch slips, its done right? (MyYellowHonda)
You might be okay. Mine slipped rather horrifically at the dragstrip at around the 16K mile mark. After bleeding the clutch there was a lot more "life" still left in the clutch. I'm now at 56K and counting on the same clutch. fwiw - there have been many drag launches since then too at ProSolo's and on the street.
Old Apr 25, 2002 | 07:36 AM
2fast4u's Avatar
I just called acura parts and he said 315 for the complete clutch kit for my car (ITR) should i just do that or try an aftermarket clutch?
Old Apr 25, 2002 | 08:23 AM
PM-Performance's Avatar
not necc done, but it will never be the same .
Old Apr 25, 2002 | 08:24 AM
houston's Avatar
dunno maybe you shoudl read the posts..
and yes that is kinda high..
Old Apr 25, 2002 | 08:26 AM
H-PIMP's Avatar
Default Re: Once a clutch slips, its done right? (houston)
Mine is slipping pretty bad right now, but only if I drag launch or powershift. I have 11k miles. I may replace it with oem, but if bleeding it can help maybe I'll do that.
Old Apr 25, 2002 | 08:36 AM
2fast4u's Avatar
Not sure what you meen by
I'm a little lost and just looking for help to get my car back on the road %100.
meece0927
Jul 2, 2013 08:15 AM
Haarstad
Jun 24, 2012 09:50 PM
altoid04
15
Nov 18, 2009 04:10 PM
NinjaTech
Aug 1, 2005 01:44 PM
zomart
Jul 23, 2003 05:51 PM
