jdm headlight question??
so i have had my front end on for about 3 months now.. but have only got around to hooking up the hid's and using the side marker light for a blinker...
i have been searching around and looking at pics of other jdm fronts to see how they have the lights wired up... can some one tell me if this would be the correct way to have everything wired up..
low beams - hid's obviously
parking lights - sidemarker
blinkers - corner lights
citylights - ??? i was think parking lights or even lowbeams?
i was also going to wire my highbeams to the yellow fog lights.. for one I NEVER use my high beams.. for 2 i dont have the jdm fog switch.. but would sooner or later get one and hook it up correctly...
hopefully this post makes some sense.. thnx in advance for any suggestions or answers
Position one turns on the city lights.
Position two turns on the low beams, in addition to the city lights.
The sidemarkers and turn signals are only supposed to be blinking when the signals are used. They should not be illuminated with either position one or two.
thnx for the heads up...
i always see side markers lit... but did not want to go that route... just for blinkers as well as the corner lights
awesome... you made my night
parking lights=city litghts...
fogs=PIAA fog lights harness+wire+switch... (i did this so that they are independent of the headlights..)
blinkers=blinkers..
but i put some electrical-tape on one of the connectors of the blinker.. so that the turn signal only blinks when i have the blinkers on...
blinkers=blinkers..
