CTR crank pulley?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style »</TD></TR><TR><TD CLASS="quote">Don't do it. It doesn't have a harmonic dampener like the OEM pulley has. In other words, it will eat your thrust bearings for lunch.</TD></TR></TABLE>
Show me a link where it directly states it will ear your thurst bearings? or will wear any bearings down dramatically?
Many people run them and yes it will wear it down more then a crank pulley that is harmonically balanced and has the damper but it will work perfectly fine for a few years.
I'm running the CTR n1 crank pulley with a 10lb flywheel and it makes such a difference on the b18b, also with a short gear tranny it pulls awesome.
Would I recomend the crank pulley for others? yes if you want to take the chance. If you want to run it, might as well install and ITR oil pump onto your engine for some better flow.
I know a few people runing it and non of them had problems.
good luck if you get it, it was worth the money I paid of it
i have one installed on my gsr motor...yes it looks good but honestly i didnt feel any difference from the weight savings.
if you want a lighter rotating assembly get a lightened flywheel. you will be happy with that, trust me
Ricochet.
Nov 2, 2004 08:05 PM
